IOS XE ctrl shift 6 equivalent
jsblach
hi,
i'm still looking for the ios xe equivalent for ctrl shift 6 on ios. how can i interrupt a domain lookup or something on ios xe?
ctrl-shift-6 x or similar wouldn't work for me
thank you all in advance
5 Replies 5
balaji.bandi
what device is this ? and what code running.
IOX XE 17.3 that works for me.
BB
it is a c9300 with 17.3., but i can't get this to work
what other information can i provide you with?
it works for me same Cat 9300 with 17.3 code on windows
BB
ammahend
works for me on widows, make sure Press Ctrl-Shift-6, then release all keys, and press x
if you have MAC then just try CTRL + 6
-hope this helps-
jsblach
you repeatedly posting that "it works for you" has magically solved my problem, thank you
