IOS XRV9000 ssh connection
jameslee
We have CISCO IOS XRv9000 installed with FW version 7.3.25.
I tried to create a ssh connection and started with creating a rsa key:
#crypto key generate rsa
When I ran it, I was getting "Operation not permitted" error on the console.
I was running the command from root account.
How to debug this issue?
I don't have the license information on this router at the moment.
Thanks.
James Lee
Harold Ritter
Hi @jameslee ,
You do not need to generate an RSA key. The only think you should need is to configure the following command:
ssh server v2
This should be enough to ssh to this device.
Harold Ritter
Hi @jameslee ,
ssh server v2
RP/0/RSP0/CPU0:.....#show mgmt-plane <<- share this
MHM
