Cisco C9200L and Zebra DZ421 Printer
TomasKyjovsky
Hi Gents,
I have brand new Cisco C9200L-24P-4X-E and Zebra ZD421 Printer.
When I try to connect printer on specific port (or any other else btw.). With static IP or DHCP, obtain no IP, no MAC address.
Checked with:
sh Mac address-table interface 1/0/15
Port speed AUTO, switchport mode access..
Any idea?!
TomasKyjovsky
Hi everyone,
problem solved! Speed on port 10Mbit, Half Duplex, Port Fast set on Access. No DHCP on printer, fixed IP. Working now!
31 Replies 31
Leo Laohoo
What firmware is the switch on?
Post the complete output to the command "sh interface G1/0/15".
TomasKyjovsky
HI @Leo Laohoo
See below:
That is not what I am asking for.
Please read and understand my response.
Sorry Sir:
And what happens if a PC is connected to the ethernet port of the printer, does the link light flash?
I tried to connect Aruba Switch... also working smooth..
What firmware is the switch on, 17.9.4?
17.3.5 ...Upgrade needed, you think?
No, not yet.
@Philip D'Ath is having similar problems (Cisco 9300L stack failing to learn MAC addresses dynamically).
I saw this post, but help me not in this time
Is this switch a member of a stack or is this a stand-alone switch?
Stand-Alone ...
If the Zebra printer is connected to port 15, is there anything active in ports 14 and/or 16?
My Computer is connected in port Gi1/0/13... in same VLAN. I tried put switch into Rack in Production, all ports and devices works fine although Zebra Printer. I tried to set Static IP in specific VLAN, Static IP in VLAN1, nothings working. Blinking well, cable in good shape.
