ip access-group 101 out not possible
petercinvest
in my access switch, i try below scripts:, interface g0/1 is connect to distribution switch through trunk
int g0/1
access-list 100 deny   ip any host (google ip address)
but it says only i can type ip access-group 101 in, if i type ip access-group 101 ? it shows only in parameter, not out.
how to fix the issue? thanks
InayathUlla Sharieff
It looks you are using wrong access list number.
your acl says number as 100 and you are defining access-group as 101.
What is the switch model and ios?
sorry, access-list 101 deny   ip any host (google ip address)
switch model: 2960-CX-8 port POE
A port ACL (on a switchport) can only be applied in the inbound direction on a switchport. It is different from a router ACL which can be applied inbound or outbound.
And with a Routed port ACL you can only apply ONE ACL per Direction  per port. So if you already have an outbound ACL then you cannot add another outbound ACl, only inbound
