Nexus 5k Upgrade vPC
Tobias Hilbert
In a vPC environnement cisco recommends to upgrade the primary switch first.
After issuing the command. "sh vpc role" i get the following output:
vPC Role status
vPC+ role                       : primary, operational secondary
Now I can't find any hints in the documentation if cisco is refering to the configured role or the operational role.
Could someone help me out here. :-)
thanks
Tobias
Hello Tobias,
The priority decides which device is the vPC primary and which is the vPC secondary. If the primary device were to reload, when the system comes back online and connectivity to the vPC secondary device (now the operational primary) is restored, the operational role of the secondary device (operational primary) will not change, to avoid unnecessary disruptions.
This behavior is achieved with a sticky-bit method, whereby the sticky information is not saved in the startup configuration, thus making the device that is up and running win over the reloaded device. Hence, the vPC primary becomes the vPC operational secondary.
If cisco say primary switch , That woudl refer to operatioanl role in vPC as that device is primary in that domain.
Hope it Helps..
-GI
6 Replies 6
Mark Malone
you should be gettking the below either primary por secondary , have you got a vpc domain setup?
7k1a# sh vpc role
vPC Role status
vPC role                        : primary
vPC system-mac                  : 00:23:04:ee:be:64
vPC system-priority             : 150
vPC local system-mac            : d8:67:d9:06:29:41
vPC local role-priority         : 150
xir-7kdist-1#
Sorry. I truncated the output. VPC is working fine. I just want to know witch switch to upgrade first.
Cisco talks about the "primary" switch. But I am not sure if configured primary or operational primary. The roles switched on my setup.
isew-nexus1f# sh vpc role
vPC Role status
Dual Active Detection Status    : 0
vPC system-mac                  : 00:23:04:ee:be:0c
vPC system-priority             : 32667
vPC local system-mac            : 00:2a:6a:f5:77:81
vPC local role-priority         : 32667
isew-nexus2f# sh vpc role
vPC Role status
vPC+ role                       : secondary, operational primary
vPC local system-mac            : 00:2a:6a:fd:61:bc
thanks
Tobias
Looks like you have same priority on each switch so either can be primary thats why your getting that message operational instead of just standard primary or secondary , 1 needs to be less or more to have an full primary/secondary mode. If youn set one of them higher or less the putput should change to like the below extract
vPC role                        : primary
vPC Role status
vPC role                        : secondary
vPC local system-mac            : d8:67:d9:05:7c:41
vPC local role-priority         : 200
Hi Mark
You are right. I should set explicit priorities to get a predictable behaviour.
thanks
Tobias
Hello Tobias,
Hope it Helps..
-GI
Hi Ganesh
"If cisco say primary switch , That woudl refer to operatioanl role in vPC as that device is primary in that domain."
Thats what i anticipated too.
Tobias
Tobias
