ip access-group in not work on nexus swith
ratha chum
I just have PO nexus switch for network environment and have go in GNS3 and EVE-NG to lab and get the following error.
On switch I configure inter-vlan routing. Configure access-list to filter traffic between LAN. The problem is when I tried to filter traffic in interface is not working(mean ACL doesn't take effect on traffic coming in interface)
Example: the follow access list
ip access-group Block_2_LAN_10
10 deny icmp any any
20 permit ip any any
interface vlan10
ip access-group Block_2_LAN_10 in
This is not work.
but if I Apply the access list to Traffic out is working.
Example:
ip access-group Block_2_LAN_10 out
interface vlan10
this is working.
What I am wrong here?
thanks for respond
22 Replies 22
Hello
You may have the acl applied in the wrong direction, see the below ACL logic on a L3 switch.
IN = Traffic orignating from within the vlan
OUT= Traffic orignating from outside the vlan
Kind Regards
Paul
HI, thanks for respond.
I understood IN/Out option. could you pls show me where I am wrong.
Hello
Where are you initicating the ping from when it fails?
Kind Regards
Paul
Ping ping from host inside VLAN 10, But ping still work.
Sergiu.Daniluk
I am not sure why ingress RACL do not work. Can you try adding "statistics per-entry" to your ACL and see if anything matches on the deny entry? You will see the statistics in the "show ip access-list" output.
Can you try to add the ACL on the L2 interfaces, using command "ip port access-group <ACL name>", and see if the deny entry works?
Sergiu
Thanks for reply.
here out.
switch# show run aclmgr
!Command: show running-config aclmgr
!Time: Mon Apr 20 09:40:05 2020
version 7.0(3)I7(4)
ip access-list Block_2_LAN_10
1 deny icmp any any
11 permit ip any any
interface Vlan10
switch# show ip access-lists
IP access list Block_2_LAN_10
1 deny icmp any any
Do you send traffic through your switch/SVI 10?
yes
Hmm maybe there is a problem with the NXOSv.
The expectations would be to:
  1. Block routed ICMP traffic ingressing on SVI10
  2. Keep and show all statistics about packets hitting the ACL entries
What version of NXOS are you running?
Cheers,
Sergiu
interface Ethernet1/1
ip port access-group Block_2_LAN_10 in
switchport access vlan 10
Here I tried to apply on L2 interface also not work.
Just to confirm, ICMP is still allowed with port ACL?
Sergiu
yes
Hello
Just to confirm, you wish to allow ICMP between hosts within the same vlan and to deny icmp between hosts in vlan 10 to any host in other vlans and you say the acl you’ve applied ingress on svi 10 to block icmp traffic from another vlan doesn’t work, if so and the ACL applied in OUT direction does work then as I stated earlier thats due to the acl logic being applied on the switch logical SVI.
Kind Regards
Paul
Hi @paul driver
I am making a presumption now that the author of this thread is using ping to confirm if ICMP is actually dropped in one direction, regardless which one is.
Having this presumption in mind, with "deny icmp any any" entry in your ACL, regardless of how the ACL is configured on SVI 10, for ingress or egress (excluding hw specific limitations), routed ICMP traffic should not work bidirectionally, meaning ping will fail - that is because either the request or reply.should be dropped.
Now question is: @ratha chum how do you verify that ICMP is actually dropped or not by ACL?
Can you give us more details about exact details about your setup (IP addresses of endpoints) and what actions you are doing? (what and where are you pinging, using tcpdump etc)
Cheers,
Sergiu
