ip access-group in not work on nexus swith
ratha chum
I just have PO nexus switch for network environment and have go in GNS3 and EVE-NG to lab and get the following error.
On switch I configure inter-vlan routing. Configure access-list to filter traffic between LAN. The problem is when I tried to filter traffic in interface is not working(mean ACL doesn't take effect on traffic coming in interface)
Example: the follow access list
ip access-group Block_2_LAN_10
10 deny icmp any any
20 permit ip any any
interface vlan10
ip access-group Block_2_LAN_10 in
This is not work.
but if I Apply the access list to Traffic out is working.
Example:
ip access-group Block_2_LAN_10 out
interface vlan10
this is working.
What I am wrong here?
thanks for respond
22 Replies 22
I want to block all icmp from vlan 10 to other vlan. Then I applied in to
block, but host from VLAN 10 still can ping other VLANs.##- Please type
your reply above this line -##
Hello
Then apply the acl in OUT direction to the logical svi interface of vlan 10.
Kind Regards
Paul
Yes, when I applied to out the ACL is working. Traffic have been
@paul driver wrote:
Hello
Well, that actually is incorrect. The logic of ACLs, at least on Nexus switches is the following:
The ingress RACL applied on VLAN 10, will apply on all traffic ingressing on SVI 10,  having destination MAC SVI 10.
The egress RACL applied on VLAN 10, will apply on all traffic egressing on SVI 10, having destination MAC of endpoints or next hop.
Same logic as the one on Layer 3 physical interfaces.
Cheers,
Sergiu
@Sergiu.Daniluk
maybe the wording differs but svi acl logic is the same which as i understand it is:
IN = traffic originating from within the vlan -
Out =traffic originating outside vlan
Kind Regards
Paul
Happy to hear that we are on the same page ^_^
But I am still confused why you suggested the OUT options, when the author wants to filter traffic in the direction "from vlan 10 to other vlan".
Sergiu
Hello
The reason is that the OP confirmed the acl applied egress is working to deny icmp as it isn't working ingress which I suspect is possibly due to some software issue with the simulation software they are using.
Kind Regards
Paul
Host the same vlan 10 allow ping each other, but block different vlan.##-
Please type your reply above this line -##
