11-13-2006 04:04 AM - edited 03-05-2019 12:46 PM
hello,
please, what is the command to enable ip accountong on the catlyst 4506.
thanks for your help
11-13-2006 04:15 AM
Hi Friend,
Unfortunately, the 'ip accounting' command is not supported on the 4000 series switches.
Please check the following link:
Ankur
*Pls rate all helpfull post
11-13-2006 05:10 AM
but i have the command "sh ip accounting" in my catalyst4506
c4506#sh ip accounting
c4506#
i want just to know what i must enter to have the result of this command
11-13-2006 05:24 AM
Hi ,
If you want to get the output of show ip accounting then you need enable ip accounting on particular interface.
ex: int f0/0
ip accouting output-packets
Then you can see hosts utilization.
hope it helps you.Plz rate it.
satish
11-13-2006 05:45 AM
the command "ip accounting output-packets" is not supported on 4506 on vlan interface configuration
11-13-2006 05:28 AM
but i have the command "sh ip accounting " on my catalyst 4506, ???
is there a way to know the trafic between two host connected to my catalyst?
thanks
11-13-2006 06:36 AM
Hi Friend,
IP Accounting is not supported on this platform you may get an option for 'sh ip accounting" because it is based on general IOS package.
Talking about to know the traffic between 2 host connected you can configure SPAN on your 4506 and can capture the traffic of 2 ports and send it on one destination port on which you can connect any machine having sniffer software.
For more information on SPAN
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_1_20/config/span.htm#1020356
Ankur
*Pls rate all helpfull post.
