Ip accounting
Robo123
Level 5
Level 5
Can some one confirm Ip accouning will be suppoted cisco 9300 running 17.06.4 version
5 Replies 5
M02@rt37
Hello @Robo123
Check here if this feature is available on your platform with this IOSxe version: https://cfnng.cisco.com/browse/switching/products
it should be OK, regarding now your licence level:
Best regards
balaji.bandi
Cat 9K support ip accouting - better to upgrade 17.9.4a suggest IOS XE before you putting production.
BB
@balaji.bandi M02@rt37 ,
Thanks for the information.can you please help me with the ip accounting configuration guide specific to 9300 platform
i mean to say accounting supported using netflow :
below example i use most of the Cat 9300 switches :
https://www.balajibandi.com/?p=1383
check below cisco guide if you like reference :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-5/configuration_guide/nmgmt/b_165_nmgmt_9300_cg/b_165_nmgmt_9300_cg_chapter_01000.html
BB
M02@rt37
