ip address forwarding
in our org we have 6509 has the core switch but it as not gateway because our gateway to the internet is thru a proxy server. but we have another connection outside if we want to use static routes. But since static routes is for destination, i want a particular server to redirect it the another connection
so need any suggestions on it ..its literally forwarding an ip address or a host to another interface
Karthik
Reza Sharifi
Hello Karthik,
You can use PBR to achieve that.  Take a look at this link for examples:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009481d.shtml
Reza
Reza Sharifi
Hello Karthik,
Reza
Ganesh Hariharan
Karthik
Hi Karthik,
If you want TCP/IP forwarding in server to server  check out the below link,
http://support.microsoft.com/kb/323339
Ganesh.H
