Ip address issue
WEERAKOO69BA
Level 4
Level 4
Hi i have one quiery.If some one assign iIp as follows,
interface Vlan3
ip address 192.168.1.5 255.255.255.248
(7addresses are alowed192.168.1.5-1.12)
interface Vlan4
ip address 192.168.1.42 255.255.255.248
(7 addresses are allowed from 192.168.1.42 -49)
interface Vlan10
ip address 192.168.1.128 255.255.255.128
**127 arredsses are allowed
192.168.1.128 - 254
My question is ,
1)if ip address 192.168.1.253 255.255.255.128
how amny addreses are allowed and what are those???(only 254 or ??)
2)ip address192.168.1.253 255.255.255.0 -If one asign IP for vlan 10,will it clash with other vlans.??
7 Replies 7
cadet alain
1)  ip address 192.168.1.253 255.255.255.128
so subnet is 192.168.1.128 and hosts go from 192.168.1.129 to 192.168.1.254 so 127 addresses as the /25 suggests
yes it will overlap with other vlans because here addresses go from 192.168.1 .1 to 192.168.1.254.
all masks greater than /24 are subnets of /24
Regards.
Alain.
alain,
Thanks a lot for the reply.That mean it will go from 192.168.1.128 -192.168.1.254
no 192.168.1.253/254 and 1to 125??
What do you mean? Can you clarify.
Regards.
Alain.
what I asked was,The ip address range will go from 192.168.1.128  to  192.168.1.254.That means the range is not as follows,
192.168.1.253
192.168.1.254
192.168.1.1
192.168.1.2
.192.168.1.3
192.168.1.126
If the range goes from .128 to .254 then the addresses are from .129 to .254
Regards.
Alain.
Thanks a lot,
But pls have a look on the folllowing  senario,
if
vlan 10
ip address 192.168.1.12 255.255.255.248
this has 7 ips alright?
are those--192.168.1.13  to 192.168.1.18
OR
192.168.1.12. to 192.168.1.6(back ward)  ????
255-248=8 is subnet increment so the range is 192.168.1.9 to 192.168.1.14 included for IP addresses.
192.168.8 is subnet and 192.168.1.15 is broadcast.
Regards.
Alain.
