IP Addressing Tool - Subnet Calculator for a range
bpotschien
Hi there,
perhaps this is the wrong section, but I'm searching for a software.
I need somethiong like an IP Subnet Calculator...
I have an 'unorganized' range of IP adresses e.g. 192.168.1.111 till 192.168.1.159.
Now I wanted to convert this range in subnets and host adresses to cover the range. In this example:
192.168.1.111 /32
192.168.1.112 /28
192.168.1.128 /27
Does anybody know a tool that automatically outputs the subnet/host addresses?
Thanks in advance
Bjoern
7 Replies 7
sstudsdahl
Level 4
Level 4
Bjoern,
There are a few tools that you can use. The first being the Cisco Subnet Calculator. You can find it at:
http://www.cisco.com/cgi-bin/Support/IpSubnet/home.pl
The second utility you might look at is the Boson Subnet Calculator. The download site is located at:
http://www.boson.com/promo/utilities.htm
A third one that you might look at is the Solarwinds Subnet Calculator. You can find it at:
http://www.solarwinds.net/Download-Tools.htm
I am sure that there are many more out there, but these should help out.
Steve
Thanks for the hints. I know the standard subnets tools well.
But I need a tool that gives me the subnets when I enter only the range: 192.168.1.111 - 159
A great site with tools for subnetting is http://www.subnetonline.com. This site has a list of several different subnet calculators, each with different characteristics. Maybe you can find the one you need here!
Michaël
Thank you for the link.
http://www.subnetonline.com/subcalc/subnet6.html is not exactly what I mean. I want to enter any network range and the tool outputs the correct subnets (e.g. for routing entries)
bpotschien
Thanks for all the replies...
The problem is solved now. A teammate has written a tool in Pearl that suffice my request.
glen.grant
Go to wildpackets.com under support and get the network calculator . It is the easiest and best one I have ever used , even does inverse masking for figuring out functions that use the inverse mask .
engahmed_1975
may be, it's too late, however I'll reply to you,
The best one is the one from solarwind, and it's free.
https://www.solarwinds.com/free-tools/advanced-subnet-calculator
Ahmed
