IP Base to Ip Base K9
Udupikrishna091
Hi Guys,
               I have 4 WS-C3560-24PS switches which is actually running Ip Base image, will I be able to upgrade it to Ip basek9 to support ssh with out spending any cost on the license or do we really need to buy them, any suggestion would be helpful
Krishna
Vivek Ganapathi
Level 4
Level 4
Yes you can. But you need a CCO account with a contract ID associated to it with permissions to download a k9 image AFAIK.
Hi Krishna,
You can download that if you have a smartnet contract or if you bought your switches from a reseller and assuming its under maintenance they should be able to provide you with the relevant image.
Kishore
