VACL and acl to secure vlan
power.srvi
hi all
i have a catalyst 3750, in this switch i have 3 vlan, i need to secure trafic between vlans but im confused ,
should i use ACL or VACL to secure ?
which is the best ?
if i use ACL to secure and limit ports besween vlan, which is the best practice to apply the acl ( on th inside or outside of interface)
regards
Reza Sharifi
If by secure you mean not allowing vlans to talk to each other, then you can use ACL on the SVIs to limit that.
thank you reza
so what is the best practice, should i put the acl on the in or out SVI ?
regards
