IP camera are reset automatically which are connected to Cisco WS C2960X Switch
Sagar Patel
Hello, We have numbers of Cisco WS C2960X 24 and 48 port PoE Switches. We have 60 Panasonic IP cameras which are attached to those switches. Currently we are facing some weird issue that some of those cameras got reset to its default configuration. Camera which got reset are also connected on different switches. So its not the issue of specific switch. We have total 9 such cameras which got reset. We also confirmed with Panasonic, they tested and confirmed that cameras are not faulty. So is there any issue with the power supplied through PoE? We have stuck here. One more point is that all switches receive power supply through a online UPS.
Please help and guide to troubleshoot this issue.
Sagar Patel
5 Replies 5
what are the exact models of the Panasonic cameras ?
Do the switch logs show anything (sh log) indcating that the ports lose power ?
    We have following camera models:
1. PI-SFW201FL
2. PI-SFW201DL
3.PI-SFW201CL
With regards,
Sagar Patel
I have problem with PTZ Camera and Cisco Switch POE
Panasonic PTZ Camera WV-X6533LN / 25.5W , Cisco Switch C2960X-24PS-L with 12 port PoE+ IEEE802.3at / Class 4 -30W max;
Problem displayed: it is operating with POE class 0 power supply connect the correct power supply
Kindly please assist to solve this problem , thanks you so much
Email: vin.bv16@gmail.com
Mark Elsen
 - Besides other reply you may want to use a centralized syslog server and send logs from the switches to it , for better overall analyzing capabilities.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hello, Yes sure, I will configure syslog for switches and update you with it..
With regards,
Patel Sagar
