IP conflict/duplicate addresses in Cisco LAN
Ayad
How is it possible to detect/locate/discover a duplicate IP address in a network (LAN)?
I have recently found in one of my LAN (remote site) that a switch has the same address as the virtual VRRP (adress of my two WAN devices). I had often many connectivity issues because of this conflict but when i connect to WAN devices i ping the shared address without any problem, thus for me no problem with the adress.
- How can I know if the adress match the VRRP or the switch ?
- Does someone know some cisco advanced command to see this in cisco routers or switchs ?
- is the show mac-address-table can give me the two mac if any conflict occurs ? so i can locate the port.
- from my switch, is there any command to have all ip address of devices connected in LAN ? or mac-addresses ?
Many thanks for help.
6 Replies 6
- To see if it is the VRRP address I would say you should use the vrrp show command to see the IP and the MAC
VRRP Show
Router# show vrrp
Ethernet0/1 - Group 1
State is Master
Virtual IP address is 10.21.0.10
Virtual MAC address is 0000.5e00.0101
-  "show arp" will show you if you have 2 MAC's or more with the same IP
- To find the direction, you can search trough the network with "show mac add add aaaa-bbbb-cccc" and you will the the port, channel, etc..
     "show ehterchannel summary" and "show cdp neigh gig" (For example)" helps to find the direction.
Hope that helps or give you some ideas.
best regards,
Sebastian
Incorrect, since per standard there cannot be more than one MAC per IP, °show arp° will never show that.
your're right Paolo, Sorry.
Maybe a syslog entry could help.
jhosa_reddy
Use the  show arp command
example,
Example:-
Switch#show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.1.1.1                -   00E0.F97A.7958  ARPA   Vlan1
Internet  10.1.1.20               0   0001.64EE.6301  ARPA   Vlan1
Note :- Red result is the duplicate address of two routers and "0" indicates duplicate address
OR
use "show cdp neighbors detail"
Example :-
Switch#show cdp neighbors detail
Device ID: Router
Entry address(es):
  IP address : 10.1.1.20
Platform: cisco C1841, Capabilities: Router
Interface: FastEthernet0/1, Port ID (outgoing port): FastEthernet0/0
Holdtime: 148
Version :
Cisco IOS Software, 1841 Software (C1841-ADVIPSERVICESK9-M), Version 12.4(15)T1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 18-Jul-07 04:52 by pt_team
advertisement version: 2
Duplex: full
Device ID: Router
Entry address(es):
Interface: FastEthernet0/2, Port ID (outgoing port): FastEthernet0/0
Holdtime: 128
Version :
Duplex: full
Switch#
Switch# show ip arp
Internet  10.1.1.20               21  0001.64EE.6301  ARPA   Vlan1
Hi reddy,
Thanks for your help.
Using the show arp or show ip arp in my router or my catalyst 2960, i see just 3 or 4 mac-address whereas i have many others workstations in the LAN.
is there any possibility or others command to have MAC or IPs addresses of all devices conencted to my LAN ?
Thanks again.
AA
