IP device tracking
ross_rulz
Level 5
Level 5
We have Cisco 3850 switches and we dont use dot1x but we need to turn off ip device tracking but when I do it from global config mode it pops up the below error:
Switch(config)#no ip device tracking
% IP device tracking is disabled at the interface level by removing the relevant configs
I've tried disabling it under interface mode even though we don use it.
Can someone please show me how to disable it globally?
Thanks.
Richard Primm
Hi Ross,
This is a known issue that we are continually working towards a resoltuion.  To solve your issue, please run the following at the interface level.
switch(config)# int range gig1/0/1 - 24
switch(config-if)# nmsp attach suppress
end
Unfortunalty we cannot do this globally, so we have to do it at the port level.  Again, we are working on a better solution in an upcoming release, but this will solve your issue for now.
PS. version 3.3 is released for the 3850 (major release)
23 Replies 23
Leo Laohoo
Go to the interface and do "no ip device track max ".  If you can't delete it, you will have to issue the command "default interface ".
We dont use the " ip device track max " under the interface mode. We dont use device tracking it is only on by default with the new switch when it came out of the box from Cisco.
Here is a sample of our interface config:
interface GigabitEthernet2/0/22
description --- User/IP Phone Connection ---
switchport access vlan 18
switchport mode access
switchport voice vlan 209
trust device cisco-phone
spanning-tree portfast
service-policy input VoIP
Any ideas?
To remove IP Device Tracking from an interface, use the command "ip device tracking max 0".
Thanks but I tried the above command and "0" is not available. See below what is available:
SW(config-if)#ip device tracking max ?
  <1-10>  Maximum devices
Any other ideas?
That's bizarre.  I am able to get this in:
Switch(config-if)#ip device track max ?
<0-65535>  Maximum devices (0 means disabled)
Can you post the output to the command "sh version"?
What happens if you run the interface command "no ip device track max 10"?
I have tried the no ip device track max 10 in interface mode and it accepts it but when I issue " sh ip device tracking int gig 2/0/22 " it still says its enabled.
SW#show ip device tracking interface gig 2/0/22
Enabled interface Configs:
Global IP Device Tracking for clients = Enabled
Global IP Device Tracking Probe Count = 3
Global IP Device Tracking Probe Interval = 30
Global IP Device Tracking Probe Delay Interval = 10
  IP Address    MAC Address   Vlan  Interface           Probe-Timeout      State    Source
Total number interfaces enabled: 64
Enabled interfaces:
  Gi1/0/1, Gi1/0/2, Gi1/0/3, Gi1/0/4, Gi1/0/5, Gi1/0/6, Gi1/0/7,
  Gi1/0/8, Gi1/0/9, Gi1/0/10, Gi1/0/11, Gi1/0/12, Gi1/0/13, Gi1/0/14,
  Gi1/0/15, Gi1/0/16, Gi1/0/17, Gi1/0/18, Gi1/0/19, Gi1/0/20, Gi1/0/21,
  Gi1/0/22, Gi1/0/23, Gi1/0/24, Gi1/1/1, Gi1/1/2, Gi1/1/3, Gi1/1/4,
  Te1/1/1, Te1/1/2, Te1/1/3, Te1/1/4, Gi2/0/1, Gi2/0/2, Gi2/0/3,
  Gi2/0/4, Gi2/0/5, Gi2/0/6, Gi2/0/7, Gi2/0/8, Gi2/0/9, Gi2/0/10,
  Gi2/0/11, Gi2/0/12, Gi2/0/13, Gi2/0/14, Gi2/0/15, Gi2/0/16, Gi2/0/17,
  Gi2/0/18, Gi2/0/19, Gi2/0/20, Gi2/0/21, Gi2/0/22, Gi2/0/23, Gi2/0/24,
  Gi2/1/1, Gi2/1/2, Gi2/1/3, Gi2/1/4, Te2/1/1, Te2/1/2, Te2/1/3,
  Te2/1/4
Here is the show version:
SW#show ver
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.02.01.SE RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 20-Mar-13 17:10 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: C3850 Boot Loader (C3850-HBOOT-M) Version 1.1, RELEASE SOFTWARE (P)
SW uptime is 4 weeks, 1 day, 19 hours, 3 minutes
Uptime for this control processor is 4 weeks, 1 day, 19 hours, 6 minutes
System returned to ROM by reload at 12:43:29 WST Sun Sep 8 2013
System restarted at 13:08:55 WST Sun Sep 8 2013
System image file is "flash:packages.conf"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
License Level: Ipbase
License Type: Permanent
Next reload license Level: Ipbase
cisco WS-C3850-24P (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FOC1722Z4J9
2 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
250456K bytes of Crash Files at crashinfo-2:.
1609272K bytes of Flash at flash:.
1609272K bytes of Flash at flash-2:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of Dummy USB Flash at usbflash0-2:.
0K bytes of  at webui:.
Base Ethernet MAC Address          : d0:c7:89:70:a7:00
Motherboard Assembly Number        : 73-12240-10
Motherboard Serial Number          : FOC17215VEG
Model Revision Number              : B0
Motherboard Revision Number        : D0
Model Number                       : WS-C3850-24P
System Serial Number               : FOC1722Z4J9
Switch Ports Model              SW Version        SW Image              Mode
     1 32    WS-C3850-24P       03.02.01.SE       cat3k_caa-universalk9 INSTALL
     2 32    WS-C3850-24P       03.02.01.SE       cat3k_caa-universalk9 INSTALL
Switch 02
Switch uptime                      : 4 weeks, 1 day, 19 hours, 6 minutes
Base Ethernet MAC Address          : d0:c7:89:70:96:80
Motherboard Serial Number          : FOC17215V33
System Serial Number               : FOC1722V19Q
Configuration register is 0x102
Hmmmmm ... I read in another post that this could be one of the known IOS bugs.
So best to upgrade the IOS on the switch then?
Ummmmm ... In this case, I am not sure.  My 3560CG, where I am able to run the command, is running 15.2(1)E.  This version, also known as IOS XE 3.5.0E for 3560/3850, is not yet available for the 3560/3850.
Personally, I'll leave this up to you since I am not yet finish with my testing of this particular IOS version.
Ok thanks for your help.
Damien Miller
I found ip device tracking was causing my clients grief due to conflicting ip addresses.  The switch ports were sending arps with a 0.0.0.0 ip at the same time the tcp stack was reinitializing and gave itself the same 0.0.0.0 ip.  Windows was not happy with that.
We performed an IOS downgrade on our access layer switches to 15.0(2)SE4, this version allowed us to disable ip device tracking.  It appears in newer versions of code(15.2) it was on by default and could not be disabled.
My experience was with 2960's though.
Damien,
To disable IP Device Tracking on a per-interface-level, use the command "ip device tracking max 0".   "0" means disable.  Don't ask me why we had to result to this but I sure heck didn't like it.
We had the same issue with a 2960s model. We also downgraded to another version and we could then change the no ip device tracking command with no issues.
Richard Primm
Hi Ross,
end
