OSPF Connectivity Issue
Paki
Hi there
Attached herewith is my OSPF network template (Image 1).
Everything is working very good.
PC-1 can PING PC-2 & OSPF is following best possible costs. When I PING PC-2 to PC-1 (& vice versa), the packet follows path as attached in image 2.
But if I remove the link between R1 (192.168.0.17/30) & R5 (192.168.0.18/30), the ICMP packets from any of these both PC(s) do not travel over any other path. They don't PING any other device except their own gateways & their builtin connected ethernet interfaces.
I also noticed that traffic is not flowing via any Serial link.
OSPF is properly establishing neighbor relationship with next hops.
What could be the possible reason for that?
Your professional advise would be appreciated.
Thank/Regards
26 Replies 26
Satwant Singh
Kindly give the output of R1, R2, R3 & R4  show ip route ospf
Dear Satwant Singh Dhaliwal !!!
Please find attached outputs of "show ip route ospf" for R1, R2, R3, R4.
I am thankful for your quick response to solve my problem.
Could you please execute this command on R1, R2, R3 and R4 and share the outputs. I would like to be sure the adjacency and if they are connected properly.
show ip ospf neighbors
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Dear Julio Moisa !!!
Attached is the file as output of "show ip ospf neighbor" on R1, R2, R3, R4 & R5.
Also please elaborate dead timers.
Thank You
Dear Yawar Aziz,
Are you sure that you removed the link between r1 and r5 ? .... but its still showing connected in these outputs:
R1#show ip route ospf
O    10.0.0.0 [110/3] via 192.168.0.18, 00:00:07, FastEthernet0/0
R1#show ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
192.168.0.30      1   FULL/DR         00:00:31    192.168.0.18    FastEthernet0/0
Please see attachment show results of "show ip route ospf" & "show ip ospf neighbor" alongwith a link detached error message from OSPF.
Thank you for your responses.
Dear AZIZ,
First of all, remove the link between R1 & R5 and then send me the command output of #show ip route 172.16.20.10 (PC1) and #sh ip route 10.0.0.10 (PC2) all the routers R1 to R5
Secondly, Advertise the 10.0.0.0/8 network correctly with 0.0.0.255 wild card mask.
R3#
router ospf 30 log-adjacency-changes network 192.168.0.24 0.0.0.3 area 0 network 192.168.0.8 0.0.0.3 area 0 network 10.0.0.0 0.255.255.255 area 0 network 192.168.0.20 0.0.0.3 area 0
You said, "Secondly, Advertise the 10.0.0.0/8 network correctly with 0.0.0.255 wild card mask." After this, the tracert from PC-1 to PC-2 is as under:
C:\>tracert 10.0.0.10
Tracing route to 10.0.0.10 over a maximum of 30 hops:
1 0 ms 0 ms 0 ms 172.16.20.1
2 0 ms 0 ms 0 ms 192.168.0.2
3 1 ms 0 ms 0 ms 192.168.0.6
4 0 ms 0 ms 0 ms 192.168.0.26
5 0 ms 1 ms 0 ms 10.0.0.10
Trace complete.
Now I executed this command with R1 - R5 link established but this time, the packet traveled from R1, R2, R5 & R4.
What that wildcard change command did with route changed?
Then, As you said, I removed the link between R1-R5 & executed show ip route 172.16.20.10 & show ip route 10.0.0.10 on every router as under:
R1#show ip route 172.16.20.10
Routing entry for 172.16.20.0/24
Known via "connected", distance 0, metric 0 (connected, via interface)
  Routing Descriptor Blocks:
  * directly connected, via FastEthernet1/0
      Route metric is 0, traffic share count is 1
R1#show ip route 10.0.0.10
Routing entry for 10.0.0.0/8
Known via "ospf 10", distance 110, metric 4, type intra area
  Last update from 192.168.0.2 on FastEthernet0/1, 00:14:47 ago
  * 192.168.0.2, from 192.168.0.26, 00:14:47 ago, via FastEthernet0/1
      Route metric is 4, traffic share count is 1
R2#show ip route 172.16.20.10
Known via "ospf 20", distance 110, metric 2, type intra area
  Last update from 192.168.0.1 on FastEthernet0/1, 00:18:24 ago
  * 192.168.0.1, from 192.168.0.17, 00:18:24 ago, via FastEthernet0/1
      Route metric is 2, traffic share count is 1
R2#show ip route 10.0.0.10
Known via "ospf 20", distance 110, metric 3, type intra area
  Last update from 192.168.0.6 on FastEthernet1/0, 00:18:36 ago
  * 192.168.0.6, from 192.168.0.26, 00:18:36 ago, via FastEthernet1/0
      Route metric is 3, traffic share count is 1
R3#show ip route 172.16.20.10
Known via "ospf 30", distance 110, metric 4, type intra area
  Last update from 192.168.0.25 on FastEthernet0/1, 00:16:31 ago
  * 192.168.0.25, from 192.168.0.17, 00:16:31 ago, via FastEthernet0/1
R3#show ip route 10.0.0.10
R4#show ip route 172.16.20.10
Known via "ospf 40", distance 110, metric 4, type intra area
  Last update from 192.168.0.30 on FastEthernet0/1, 00:17:22 ago
  * 192.168.0.30, from 192.168.0.17, 00:17:22 ago, via FastEthernet0/1
R4#show ip route 10.0.0.10
Known via "ospf 40", distance 110, metric 3, type intra area
  Last update from 192.168.0.30 on FastEthernet0/1, 00:20:10 ago
  * 192.168.0.30, from 192.168.0.26, 00:20:10 ago, via FastEthernet0/1
R5#show ip route 172.16.20.10
% Network not in table
R5#show ip route 10.0.0.10
The question arises that even routers are showing connected status of 172.16.20.10 & 10.0.0.10, then why these both PC can not access any interface of R2, R3, R4 & R5 except their immediate connected WAN interfaces. I mean no ICMP packet can get at any router interfaces on any IP.
Dear Sir!!!
I am thankful for your swift replies & for your interest solving my problem.
Dear AZIZ,
Perfect my friend, we are very close. Now the biggest question is that when link is removed between R1 & R5  then why there is no route of PC-1 and PC2 networks (It should not happen, coz R5 have ospf neighbor-ship with R2, R4 and R3 )?
Kindly share the below detail of R5:
1/ Sh run
2/ Sh ip route connected
3/ sh ip route ospf (Both cases)
4/ sh ip int br
5/ sh ip os nei
6/ sh ip os database
R5#show run
Building configuration...
Current configuration : 992 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
no ipv6 cef
no ip domain-lookup
spanning-tree mode pvst
interface FastEthernet0/0
ip address 192.168.0.18 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.0.25 255.255.255.252
duplex auto
speed auto
interface Ethernet0/1/0
ip address 192.168.0.30 255.255.255.252
duplex auto
speed auto
interface FastEthernet1/0
ip address 192.168.0.6 255.255.255.252
interface Vlan1
no ip address
shutdown
router ospf 50
network 192.168.0.28 0.0.0.3 area 0
network 192.168.0.16 0.0.0.3 area 0
network 192.168.0.4 0.0.0.3 area 0
ip classless
ip flow-export version 9
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
R5#show ip route connected
C    192.168.0.4/30 is directly connected, FastEthernet1/0
C    192.168.0.16/30 is directly connected, FastEthernet0/0
C    192.168.0.24/30 is directly connected, FastEthernet0/1
C    192.168.0.28/30 is directly connected, Ethernet0/1/0
R5#show ip route ospf   (R1-R5 links connected)
O       10.0.0.0 [110/2] via 192.168.0.26, 00:09:20, FastEthernet0/1
172.16.0.0/24 is subnetted, 1 subnets
O       172.16.20.0 [110/2] via 192.168.0.17, 00:08:35, FastEthernet0/0
192.168.0.0/30 is subnetted, 8 subnets
O        192.168.0.0 [110/2] via 192.168.0.5, 00:08:35, FastEthernet1/0
O        192.168.0.8 [110/1563] via 192.168.0.26, 00:09:20, FastEthernet0/1
O        192.168.0.12 [110/1563] via 192.168.0.17, 00:08:35, FastEthernet0/0
O        192.168.0.20 [110/65] via 192.168.0.26, 00:09:20, FastEthernet0/1
R5#show ip route ospf   (R1-R5 link disconnected)
no output was shown
R5#show ip int brief   (R1-R5 link connected)
Interface                     IP-Address            OK?        Method      Status      Protocol
FastEthernet0/0        192.168.0.18          YES         manual         up             up
FastEthernet0/1        192.168.0.25          YES         manual         up             up
Ethernet0/1/0            192.168.0.30          YES         manual         up             up
FastEthernet1/0        192.168.0.6            YES         manual         up             up
Vlan1                          unassigned           YES           unset administratively down down
R5#show ip ospf neighbor   (R1-R5 link connected)
192.168.0.26          1   FULL/BDR         00:00:39     192.168.0.26 FastEthernet0/1
192.168.0.17          1   FULL/BDR         00:00:37     192.168.0.17 FastEthernet0/0
192.168.0.29          1   FULL/BDR         00:00:30     192.168.0.29 Ethernet0/1/0
192.168.0.9            1   FULL/BDR         00:00:30     192.168.0.5 FastEthernet1/0
R5#show ip ospf database
OSPF Router with ID (192.168.0.30) (Process ID 50)
Router Link States (Area 0)
Link ID                ADV Router     Age       Seq#           Checksum     Link       count
192.168.0.26     192.168.0.26    254    0x8000000a   0x00e170        6
192.168.0.9       192.168.0.9      249    0x80000009   0x001f82         4
192.168.0.29     192.168.0.29    248    0x80000009   0x000351        5
192.168.0.30     192.168.0.30    231    0x80000015   0x00a569        4
192.168.0.17     192.168.0.17    231    0x80000016   0x00a020        5
Net Link States (Area 0)
192.168.0.25     192.168.0.30     255     0x8000000b    0x0057e5
192.168.0.6       192.168.0.30     255     0x8000000c    0x00adb2
192.168.0.30     192.168.0.30     250     0x8000000d    0x005ba5
192.168.0.1       192.168.0.17     248     0x80000003    0x00f1b3
192.168.0.18     192.168.0.30     231     0x8000000e    0x0061e8
One more thing.
Aside of this that R1-R5 link is broken, atleast these PC(s) should PING WAN interfaces of Serial Cable. These PC(s) are not even PINGing them.
What to do?
I don't think it is related to ospf.  do one more thing ... give the output  of  sh ip route ospf on R2  & R4 (Both cases  up/down)
R2#show ip route ospf   (R1-R5 link established)
O 10.0.0.0 [110/3] via 192.168.0.6, 00:57:11, FastEthernet1/0
O 172.16.20.0 [110/2] via 192.168.0.1, 02:09:59, FastEthernet0/1
O 192.168.0.12 [110/1563] via 192.168.0.1, 02:09:59, FastEthernet0/1
O 192.168.0.16 [110/2] via 192.168.0.1, 01:09:27, FastEthernet0/1
[110/2] via 192.168.0.6, 01:09:27, FastEthernet1/0
O 192.168.0.20 [110/66] via 192.168.0.6, 00:57:11, FastEthernet1/0
O 192.168.0.24 [110/2] via 192.168.0.6, 00:57:11, FastEthernet1/0
O 192.168.0.28 [110/11] via 192.168.0.6, 02:09:59, FastEthernet1/0
R2#show ip route ospf   (R1-R5 link disconnected)
O 10.0.0.0 [110/3] via 192.168.0.6, 00:58:11, FastEthernet1/0
O 172.16.20.0 [110/2] via 192.168.0.1, 02:10:59, FastEthernet0/1
192.168.0.0/30 is subnetted, 7 subnets
O 192.168.0.12 [110/1563] via 192.168.0.1, 02:10:59, FastEthernet0/1
O 192.168.0.20 [110/66] via 192.168.0.6, 00:58:11, FastEthernet1/0
O 192.168.0.24 [110/2] via 192.168.0.6, 00:58:11, FastEthernet1/0
O 192.168.0.28 [110/11] via 192.168.0.6, 02:10:59, FastEthernet1/0
R4#show ip route ospf   (R1-R5 link connected)
O 10.0.0.0 [110/3] via 192.168.0.30, 01:00:03, FastEthernet0/1
O 172.16.20.0 [110/4] via 192.168.0.30, 00:01:57, FastEthernet0/1
O 192.168.0.0 [110/3] via 192.168.0.30, 02:12:50, FastEthernet0/1
O 192.168.0.4 [110/2] via 192.168.0.30, 02:12:50, FastEthernet0/1
O 192.168.0.8 [110/66] via 192.168.0.30, 01:01:23, FastEthernet0/1
O 192.168.0.16 [110/2] via 192.168.0.30, 00:00:03, FastEthernet0/1
O 192.168.0.24 [110/2] via 192.168.0.30, 01:00:03, FastEthernet0/1
R4#show ip route ospf   (R1-R5 link disconnected)
O 10.0.0.0 [110/3] via 192.168.0.30, 00:59:08, FastEthernet0/1
O 172.16.20.0 [110/4] via 192.168.0.30, 00:01:03, FastEthernet0/1
O 192.168.0.0 [110/3] via 192.168.0.30, 02:11:55, FastEthernet0/1
O 192.168.0.4 [110/2] via 192.168.0.30, 02:11:55, FastEthernet0/1
O 192.168.0.8 [110/66] via 192.168.0.30, 01:00:28, FastEthernet0/1
O 192.168.0.24 [110/2] via 192.168.0.30, 00:59:08, FastEthernet0/1
Whether I remove the R1-R5 link or not, these both do not show any OSPF adjacency or neighbor detached message
I tried in gns3, but i have not faced any issue. Everything is working fine whether link is up or down:
R5#Sh ip route ospf (link working R1 to R5)
O 192.168.1.0/24 [110/2] via 15.1.1.1, 00:01:03, FastEthernet0/0
O 192.168.2.0/24 [110/11] via 35.1.1.1, 00:07:01, Ethernet1/3
R5#Sh ip route ospf (link disconnected R1 to R5)
O 192.168.1.0/24 [110/75] via 45.1.1.1, 00:00:08, Ethernet1/4
                             [110/75] via 25.1.1.1, 00:00:08, Ethernet1/2  (Now Equal cost 2 routes from R2 & R4)
O 192.168.2.0/24 [110/11] via 35.1.1.1, 00:07:30, Ethernet1/3
