IP forwarding to 2 destinations
Dear all,
I need your point of view on a customer request.
I have aclient connected to f0/1 of a router which sends UDP packets to a server connected on the F0/0 of the same router..
My customer would like to have these UDP packets on 2 servers. One locally and the other one is remote. We can't use Multicast routing.
Here is a solution in the router configuration to allow this kind of request.
Thanks a lot for your help.
Jean-Yves
Jon Marshall
Jean-Yves
I'm not sure there is going to be a way to do this as the router treats the packet as a unicast packet so it will not create a second copy of it.
The only solutions i can think of are -
1) configure the source to send the packets to both destinations
or
2) use multicast which i appreciate you have already said they don't want to do but this is precisely what multicast was designed to do.
Jon
Jon Marshall
Jean-Yves
or
Jon
Thanks jon for your answer, this is what I think, I will suggest to make a GRE tunnel to the second server to allow multicast without routing it on all routers.
Br,
Jean-Yves
