IP Multicasting Anycast RP - MSDP
DevNet Engineer
Hi everone,
what is the difference between Anycast RP and MSDP? Does MSDP requires point-to-point connection to the peer? and Anycast RP does not require?
5 Replies 5
Harold Ritter
The Anycast RP solution uses MSDP to exchange source active (SA) messages between the two RPs. Please refer to the following document for more information about Anycast RP.
https://www.cisco.com/c/en/us/td/docs/ios/solutions_docs/ip_multicast/White_papers/anycast.html
Hi Harold,
Thanks for the document. Now, it is a little bit more clearer. But, I still have some questions:
1) do I still need point-to-point connection between the peers?
2) what is the difference between ip pim rp-candidate x.x.x.x and ip msdp originator-id x.x.x.x in msdp configuration?
Good morning,
You do not need a point to point between the two RPs. Normaly the connection is between the loopback address of the two RP.
The first command is to define the router as an BSR RP candidate and the second one is used to set the source address for the messages flowing between the two MSDP peers. Note that BSR or auto RP is generally not needed when deploying Anycast RP. Static RP is normally sufficient.
Hi Harold,
Thanks a lot for the Information.
As I understand, Anycast RP- MSDP is load sharing and RP hot backup, my Question is how can I make the RP redunancy determnistic, that means let's say I have two L3 switches ( core switches/Spine) as in the attached diagram and I want the only working RP is in Core/Spine L3 switch 1(CSW1), and in case a failure of CSW1, then then automatically switchover to RP-CSW2.
how it would be the configuration in this case
Best Regards,
The whole idea behind Anycast RP is to have the two RPs active simultanously and to use MSDP to synchronize the active sources between them. If having an active/standby is important in your scenario, you will need to use other tecniques, such as auto-rp or BSR.
