06-16-2014 12:00 AM - edited 03-07-2019 07:44 PM
I am using dynamic natting in packet tracer. But packet tracer does not seem to support "ip nat inside/outside destination..." command. Can anyone confirm this?
06-16-2014 02:32 AM
Hi Hassan,
Yeah. Routers in Packet tracer doesn't support this command <ip nat inside destination>. You can have the dynamic translation created in an alternate methods to suit your requirement and test.
Hope this clears your doubt.
Karthik
06-16-2014 02:59 AM
Actually it supports the "ip nat inside source" command but not "ip nat inside destination" command. Can you kindly refer me to the alternative methods for the destination command.
Thanks.
06-16-2014 03:18 AM
Hi Hassan,
Yeah. It supports the ip nat inside source / list /outside source... etc. You can refer the below provided overview document to understand which way can fullfill your requirement.
http://www.cisco.com/en/US/technologies/tk648/tk361/tk438/technologies_white_paper09186a0080091cb9.html
Hope this helps.
Karthik
06-16-2014 03:25 AM
Thanks Karthik. It does not even support "ip nat outside" :( Can you confirm that latest versions of Packet Tracer also don't support it? I m using ver 5.0.
hassan
06-16-2014 03:30 AM
Hi Hassan,
I am using version 6.0.1. In that ip nat outside <source> it supports.
Karthik
06-19-2014 04:57 AM
Thanks for the Help.
