IP Nat outside blocks SSH & ICMP from WAN to outside int?
I have a Cisco ISR 4400 series with a very simple set up. I have an inside LAN interface and a WAN interface. When IP NAT outside is on my WAN facing interface, my LAN can access the internet, however, I can not SSH or Ping the WAN interface from the internet. If I remove IP NAT Outside from my WAN interface, I obviously lose internet connection for my LAN but am able to ping and ssh from the internet into my router.... I am pulling my hair out over this - please help!
Building configuration...
Current configuration : 3780 bytes
! Last configuration change at 12:36:19 UTC Fri Apr 27 2018 by xxx
version 15.5
no platform punt-keepalive disable-kernel-core
hostname Orange
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
no ip domain lookup
ip domain name rtr.xx.com
ip dhcp excluded-address 10.0.25.1 10.0.25.49
ip dhcp pool internal-lan
import all
network 10.0.25.0 255.255.255.0
default-router 10.0.25.1
dns-server 8.8.8.8
domain-name xx-xx.com
subscriber templating
license udi pid ISR4451-X/K9 sn FOC211587U8
license boot level securityk9
username xx privilege 15 password 0 xx
redundancy
mode none
vlan internal allocation policy ascending
class-map type inspect match-any inside-outside-class
match protocol tcp
match protocol udp
match protocol icmp
match protocol dns
match protocol http
match protocol https
class-map type inspect match-any outside-inside-class
match protocol tcp
match protocol udp
match protocol icmp
match protocol http
match protocol dns
class-map type inspect match-any out-self-class
match protocol icmp
match protocol tcp
match protocol udp
match protocol http
class-map type inspect match-any self-out-class
match protocol icmp
match protocol tcp
match protocol udp
match protocol http
policy-map type inspect self-out-policy
class type inspect self-out-class
  inspect
class class-default
  drop log
policy-map type inspect outside-inside-policy
class type inspect outside-inside-class
  inspect
class class-default
  drop log
policy-map type inspect inside-outside-policy
class type inspect inside-outside-class
  inspect
class class-default
  drop log
policy-map type inspect out-self-policy
class type inspect out-self-class
  inspect
class class-default
  drop log
zone security outside
zone security inside
zone-pair security inside-outside source inside destination outside
service-policy type inspect inside-outside-policy
zone-pair security out-self source outside destination self
service-policy type inspect out-self-policy
zone-pair security outside-inside source outside destination inside
service-policy type inspect outside-inside-policy
zone-pair security self-out source self destination outside
service-policy type inspect self-out-policy
interface Loopback1
ip address 11.0.1.1 255.255.255.0
interface GigabitEthernet0/0/0
ip address 10.0.25.1 255.255.255.0
ip nat inside
zone-member security inside
negotiation auto
interface GigabitEthernet0/1/0
ip address 84.x.x.x 255.255.255.252
ip nat outside
zone-member security outside
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
ip nat inside source list 100 interface GigabitEthernet0/1/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 84..x.x.x
access-list 100 permit ip any any
control-plane
line con 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login local
transport input ssh
end
2 Accepted Solutions
Richard Burts
I believe that your issue is related to using permit any any in the ACL that controls nat
at a minimum I would change this and specify 10.0.25.0 as the source subnet. Even better would be to change the ACL from an extended access list to a standard access list which would specify 10.0.25.0 as the source subnet.
Rick
Rick
I did try this but to no avail.
You'll have to forgive me as I am new to this but, how would changing what gets natted from inside to out affect my ability to ping my outside interface from outside? As I am not trying to ping any of the interior parts of the network, just the outside interface?
Cheers
5 Replies 5
Richard Burts
Rick
Rick
Cheers
I have seen situations where using permit any any in ACL to control nat did create problems with access on outside interface. I am not sure what caused it but assume that if the router is configured to translate everything that it impacts its ability to process and respond to ping and SSH. If changing the ACL did not solve the problem I would suggest removing the nat statement on the outside interface and see if the behavior changes. (see if this is some kind of nat issue or is some other type of issue)
Rick
Rick
Made a typo, this worked but would still love a brief explanation if you have time :)
thanks a million
Glad to know that there was a typo and that changing the ACL did fix the problem. As I said I am not sure of the explanation but believe that configuring the router to translate "everything" going out the outside interface does impact the ability to process and respond to packets received on the outside interface. Thank you for marking this question as solved. This will help other readers in the forum to identify discussions that have helpful information. These forums are excellent places to ask questions and to learn about networking. I hope to see you continue to be active in the forums.
Rick
Rick
