IP not working
vaib7av.shirkul
In one my remote branch IP range is
10.12.15.24 / 29
Default gateway - 10.12.15.25
Host IP - 10.12.15.26 - 30
Broadcast IP - 10.12.15.31
Now the problem is 10.12.15.27 IP not working. That IP can ping DG.
But cant open any HO applications.
Earlier its working fine.
When I use .27 IP as a DG its working but .25 not worked.
There is no access-list.
Kindly suggest
Peter Paluch
It is difficult to understand your description of the problem. Are you saying that the workstation 10.12.15.27 can not access network servers (applications) outside its own network? Can it access services within its network? If it can ping the default gateway, can it ping anything beyond it? What does the traceroute command say?
Try to make this kind of basic troubleshooting to narrow down the problem.
Best regards,
Peter
