IP Overlap issues
Marques McPherson
Community Member
I am trying to intergrate my wireless router into my 4300 Router I believe I have done everything right however I am getting an overlap error with my subinterface. I don't know how to fix this because on that VLAN which is a client VLAN (VLAN2) has mainly static IP's except for a few. I am connected to a Layer2 SG-300-52p (via port 49) and there are 5 other switches off of that. I believe I am doing everything right but IP's are not my strong suit.
wireless router IP's: (192.168.0.229) LAN side (192.31.83.238) WAN side.
Cisco 4300:
version 15.5
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime
service timestamps log datetime
service password-encryption
service compress-config
no platform punt-keepalive disable-kernel-core
hostname MasterControlRouter
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging count
logging snmp-authfail
logging userinfo
no logging rate-limit
no logging cns-events
enable secret 5 $1$ml1a$SyIYjZdtSLlKif4W6qbTK1
aaa new-model
aaa session-id common
no ip source-route
no ip gratuitous-arps
no ip bootp server
no ip domain lookup
ip domain name okstate.edu
ip dhcp excluded-address 192.168.0.1 192.168.0.149
ip dhcp excluded-address 192.168.0.177 192.168.0.253
ip dhcp pool MC1
network 192.168.0.0 255.255.255.0
domain-name okstate.edu
dns-server 139.78.100.2
default-router 192.168.0.1
lease 7
subscriber templating
license udi pid ISR4321/K9 sn FDO21032SKK
archive
log config
logging enable
logging size 1000
hidekeys
username ITLEAdmin privilege 15 secret 5 $1$rIJz$XTOgNdDTZglXiwpAjUH1B1
redundancy
mode none
vlan internal allocation policy ascending
ip tcp synwait-time 10
ip tcp path-mtu-discovery
ip telnet source-interface Loopback0
lldp run
interface Null0
no ip unreachables
interface Loopback0
ip address 192.168.4.198 255.255.255.192
interface GigabitEthernet0/0/0
description MY_LAN
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
negotiation auto
interface GigabitEthernet0/0/0.2
description Evertz
encapsulation dot1Q 2
ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet0/0/0.3
description Dante
encapsulation dot1Q 3
interface GigabitEthernet0/0/0.4
description Broadcast
encapsulation dot1Q 4
ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet0/0/0.5
description Business
encapsulation dot1Q 5
ip address 192.168.3.1 255.255.255.0
interface GigabitEthernet0/0/0.6
description Managment
encapsulation dot1Q 6
ip address 192.168.4.1 255.255.255.192
interface GigabitEthernet0/0/1
description Internet
ip address dhcp
ip nat outside
ip access-group MY_WAN in
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
router ospf 10
router-id 192.168.4.198
network 192.168.0.0 0.0.0.255 area 0
network 192.168.1.0 0.0.0.255 area 0
network 192.168.2.0 0.0.0.255 area 0
network 192.168.3.0 0.0.0.255 area 0
network 192.168.4.0 0.0.0.127 area 0
network 192.168.4.198 0.0.0.0 area 0
ip nat inside source list MY_LAN interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface Loopback0
ip route profile
ip ssh time-out 60
ip ssh source-interface Loopback0
ip ssh version 2
ip access-list standard MY_LAN
permit 192.168.0.0 0.0.0.255
ip access-list extended MY_WAN
permit tcp any any
deny tcp any any
permit ip any any
logging history size 20
logging source-interface Loopback0
control-plane
line con 0
exec-timeout 0 0
logout-warning 60
stopbits 1
line aux 0
no exec
stopbits 1
line vty 0
exec-timeout 0 0
logging synchronous
transport input telnet ssh
line vty 1 4
exec-timeout 9 0
logging synchronous
end
Layer 2 SG-300-52p:
v1.4.7.5 / R800_NIK_1_4_194_194
CLI v1.0
set system mode switch
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 2-6
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname MasterControlSW
line console
exec-timeout 0
exit
line ssh
exec-timeout 0
exit
line telnet
exec-timeout 5
exit
username ITLEAdmin password encrypted 05f3d5d2e34aa1fbcb96de4f40309ddcd6687979 privilege 15
ip http timeout-policy 0
clock timezone " " 0 minutes 0
interface vlan 2
name Evertz
ip address 192.168.0.5 255.255.255.0
no ip address dhcp
interface vlan 3
name Dante
interface vlan 4
name Broadcast
interface vlan 5
name Business
interface vlan 6
name Management
interface gigabitethernet1
switchport mode access
switchport access vlan 2
interface gigabitethernet2
switchport trunk allowed vlan add 3-6
switchport trunk native vlan 2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet12
interface gigabitethernet13
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
interface gigabitethernet18
interface gigabitethernet19
interface gigabitethernet20
interface gigabitethernet21
interface gigabitethernet22
interface gigabitethernet23
interface gigabitethernet24
interface gigabitethernet25
interface gigabitethernet26
interface gigabitethernet27
interface gigabitethernet28
interface gigabitethernet29
interface gigabitethernet30
interface gigabitethernet31
interface gigabitethernet32
interface gigabitethernet33
interface gigabitethernet34
interface gigabitethernet35
interface gigabitethernet36
interface gigabitethernet37
interface gigabitethernet38
interface gigabitethernet39
interface gigabitethernet40
interface gigabitethernet41
interface gigabitethernet42
interface gigabitethernet43
interface gigabitethernet44
interface gigabitethernet45
interface gigabitethernet46
interface gigabitethernet47
interface gigabitethernet48
interface gigabitethernet49
switchport trunk allowed vlan add 2
exit
ip default-gateway 192.168.0.1
15 Replies 15
I can ping from anywhere, Laptop, switch, router. all places. Would I need a crossover cable for this to work? just thought about that.
