Point to Point
TristanGude
How to create a Point to Point VLAN-VLAN connection with two IRS 4451-X
Julio E. Moisa
A point to point represents the connection between 2 interfaces from different routers, have you using any Switch ethernet module.
Ethernet Switch
NIM-ES2-4 Yes Yes Yes Yes Yes 16.4.1 3.15 Cisco 4-Port Gigabit Ethernet Switch NIM
NIM-ES2-8 Yes Yes Yes Yes Yes 16.4.1 3.15 Cisco 8-Port Gigabit Ethernet Switch NIM
NIM-ES2-8-P Yes Yes Yes Yes Yes 3.15 Cisco 8-Port Gigabit Ethernet Switch NIM with PoE Support
SM-X-ES3-16-P Yes Yes Yes 3.10 16-port POE layer 2/3 EtherSwitch Service Module
Data Sheet    Q&A
SM-X-ES3-24-P Yes Yes Yes 3.10 24-port POE layer 2/3 EtherSwitch Service Module
Data Sheet    Q&A
SM-X-ES3D-48-P Yes Yes 3.11 48-port POE layer 2/3 EtherSwitch Service Module
Data Sheet    Q&A
Router1 fa0/0 --------- fa0/0 Router2
The config could be, for example:
ROUTER 1
vlan 100
interface vlan 100
ip address 10.0.100.1 255.255.255.252
no shut
interface f3/1
description TO-ROUTER2
switchport
switchport access vlan 100
switchport mode access
no shut
ROUTER 2
vlan 100
interface vlan 100
ip address 10.0.100.2 255.255.255.252
no shut
interface f3/1
description TO-ROUTER1
switchport
no shut
Please rate the comment if it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
