IP Phone 802.1x mab authenticaon
tim.zhao
Hi everyone,
We have configured 802.1x wired authentication with NPS server.
We enable mab for ip-phone authentication.
Here is our interface configuration:
interface GigabitEthernet0/9
switchport access vlan 21
switchport mode access
switchport voice vlan 2
authentication event fail action next-method
authentication event server dead action authorize vlan 31
authentication event no-response action authorize vlan 31
authentication event server alive action reinitialize
authentication host-mode multi-auth
authentication order mab dot1x
authentication priority dot1x mab
authentication port-control auto
authentication periodic
authentication timer reauthenticate 300
mab
mls qos trust device cisco-phone
mls qos trust cos
dot1x pae authenticator
dot1x timeout quiet-period 5
dot1x timeout tx-period 5
dot1x timeout supp-timeout 5
spanning-tree portfast edge
Here is my question:
When the NPS server down,or PC fail to authenticate, PC would assign to vlan 31,that's fine.
But when IP-Phone fail to authenticate ,it support to assign to vlan 2 not vlan 31.
How to deal with this scenarios?
Thank for any answers.
Best Regards,
Tim
Seb Rupik
Hi there,
Add this line to your interface config:
authentication event fail action authorize vlan 2
cheers,
Seb.
7 Replies 7
Seb Rupik
Hi there,
cheers,
Seb.
Thank you so much..
Hi there,
I have added authentication event fail action authorize vlan 2, but it didn't work...
here is my configuration:
ip device tracking maximum 5
authentication event server dead action authorize voice
authentication violation restrict
mab
mls qos trust cos
sho cdp neighbors gigabitEthernet 0/9
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID Local Intrfce Holdtme Capability Platform Port ID
SEP204C9EB3820C Gig 0/9 126 H P M IP Phone Port 1
sho mac add int gi 0/9
Mac Address Table
Vlan Mac Address Type Ports
31 204c.9eb3.820c STATIC Gi0/9
Total Mac Addresses for this criterion: 1
IP-phone was assigned to vlan 31
What switch model and IOS version are you using?
Hi there,
WS-C2960X-24PS-L 15.2(7)E0a
Thank you
Can you share a full AAA debug of when a client connects to this part and you believe an authentication failure occurs?
Can you confirm from the NPS that an Access-Reject message is actually sent for the client?
cheers,
Seb.
Having just read through the prerequisites, your switchport needs to be in single-host mode for this feature to work:
authentication host-mode single-host
cheers,
Seb.
