ip port-map command in Denali 16.3.x
fashour
What is the Denali 16.3.x equivelent to the command: ip port-map http port 8080 I am trying to configure cwa in an enviroment where browser proxy is in use.
5 Replies 5
hslai
I found an existing bug -- CSCvg82779.
Thank you for getting back to me. I cannot see the details of this bug. can you post the details here?
hslai
The bug is simply saying this particular configuration command is currently not available in 16.3.3.
hslai
After skimming through the case notes of the TAC case opening that defect, it's a gap from the previous IOS trains and the team raised a feature request on it
If you needing this, please also discuss it with your account team and ask them to follow it up with the switching PM team.
Thank you for the help.
