Issue with INPUT errors, CRC and Frames
raj
Level 2
Level 2
Hello Experts,
From last One week I am fully facing the issue with INPUT errors, CRC and Frames. Please find the below details. That is affected on my job, even lot of times I am checking the pots and cables and duplex, speed but continuously errors are increasing.I am only the person of in my organization, Please help me to find out the problem.
Now I am using CISCO 2911 router, every interfaces getting the errors like that only
Router#sh int g0/1
GigabitEthernet0/1 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is 00c8.8b61.5371 (bia 00c8.8b61.5371)
  Internet address is 125.99.247.249/29
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 2/255, rxload 1/255
  Keepalive set (10 sec)
  Full Duplex, 100Mbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:02, output 00:00:00, output hang never
  Last clearing of "show interface" counters 01:32:49
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 102000 bits/sec, 59 packets/sec
  5 minute output rate 904000 bits/sec, 97 packets/sec
     232879 packets input, 50659461 bytes, 0 no buffer
     Received 1833 broadcasts (0 IP multicasts)
     14546 input errors, 7274 CRC, 6472 frame, 0 overrun, 0 ignored
     0 watchdog, 288 multicast, 0 pause input
     343302 packets output, 368712945 bytes, 0 underruns
     185 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Router#
2 Accepted Solutions
Leo Laohoo
Post the complete output to the following commands:
1.  sh run interface G0/1; and
2.  sh controll G0/1
I am suspecting the interface configuration of the port has hard-coded the speed and duplex settings and this will be reflected by the high amount of collisions.
Configure speed and duplex settings to "auto".
23 Replies 23
Leo Laohoo
2.  sh controll G0/1
Thank you SIR,
Every day I am getting more errors and every 10 minutes I was cleared the errors but i don't know the exact solution because I am alone. Every minute I am searching for resolution, and I have one doubt about RJ45, is it ok for router to switch connection?
1.sh run interface G0/1
Router#sh run int g0/1
Building configuration...
Current configuration : 192 bytes
interface GigabitEthernet0/1
 ip address 192.168.1.1 255.255.255.0 secondary
 ip address 125.99.247.249 255.255.255.248
 ip nat inside
 ip virtual-reassembly in
 duplex full
 speed 100
end
2.  sh controll G0/1
Router#sh controll g0/1
Interface GigabitEthernet0/1
 = Hardware =
Hardware is PLATFORM SGMII INTERFACE
HWIDB: 3DDEC8B0, INSTANCE: 3DDED600, FASTSEND: 300B2020, MCI_INDEX: 0
Route Cache Flag: 11
= Media  RJ45 =
Media Change Count: 1
PORT IPD Registers:
        BP_PAGE_CNT: 0x0000000000000001, BP_CNTS_PRX: 0x0000000000000000
GMX Registers:
        RXX_INT_REG: 0x0000000000000810, RXX_INT_EN : 0x0000000000000000
        PRTX_CFG   : 0x0000000000003005, RXX_FRM_CTL: 0x0000000000000077
        RXX_FRM_CHK: 0x00000000000003BA, RXX_FRM_MIN: 0x0000000000000000
        RXX_FRM_MAX: 0x0000000000000000, RXX_JABBER : 0x0000000000002580
        RXX_DECISIO: 0x0000000000000018, RXX_FRM_CTL: 0x0000000000000077
        RXX_FRM_CHK: 0x00000000000003BA, RXX_JABBER : 0x0000000000002580
        RXX_DECISIO: 0x0000000000000018, RXX_UDD_SKI: 0x0000000000000000
        RXX_STATS_C: 0x0000000000000000, RXX_IFG    : 0x0000000000000008
        RXX_PAU_DRP: 0x0000000000000000, RXX_STATS_P: 0x00000000003379B2
        RXX_STAT_CT: 0x0000000000000000, RXX_STATS_D: 0x00000000000027C8
        RXX_STAT_DR: 0x0000000000000000, RXX_STATS_B: 0x0000000000014EF7
        SMACX      : 0x000000C88B615371
        TXX_SGMII_C: 0x0000000000000001, TXX_CTL    : 0x0000000000000003
        RX_PRTS    : 0x0000000000000004, RX_BP_DROP : 0x0000000000000002
        RX_BP_ON   : 0x0000000000000040, RX_BP_OFF  : 0x0000000000000010
        TXX_PAU_PKT: 0x0000000000000060, TXX_MIN_PKT: 0x000000000000003B
        TXX_PAU_PKI: 0x0000000000000010, TXX_SOFTPAU: 0x0000000000000000
        TXX_PAU_TGO: 0x0000000000000000, TXX_PAU_ZRO: 0x0000000000000001
        INF_MODE   : 0x0000000000000022, TX_PRTS    : 0x0000000000000004
        TX_IFG     : 0x0000000000000048, TX_JAM     : 0x00000000000000EE
        TX_COL_ATMP: 0x0000000000000010, TX_PAU_DMAC: 0x00000180C2000001
        TX_PAU_TYPE: 0x0000000000008808, TX_OVR_BP  : 0x0000000000000F0F
        TX_BP      : 0x0000000000000000, TX_CORRUPT : 0x000000000000000F
        RX_PRT_INFO: 0x0000000000000000, GMX_STAT_BP: 0x0000000000000000
        TX_INT_REG : 0x0000000000000000, TX_INT_EN  : 0x0000000000000000
        ADR_CAM0   : 0x0000000000000000
        ADR_CAM1   : 0x00000000000000C8
        ADR_CAM2   : 0x000000000000008B
        ADR_CAM3   : 0x0000000000000061
        ADR_CAM4   : 0x0000000000000053
        ADR_CAM5   : 0x0000000000000071
        ADR_CTL    : 0x000000000000000D, CAM_EN     : 0x00000000000000FF
        TXX_STAT0  : 0x0000000000000000, TXX_STAT1  : 0x0000000000000000
        TXX_STAT2  : 0x000000018740924C, TXX_STAT3  : 0x000000000052639B
        TXX_STAT4  : 0x00047EFE00000000, TXX_STAT5  : 0x0001DA000006204B
        TXX_STAT6  : 0x0001C00D0001E345, TXX_STAT7  : 0x0000000000424700
        TXX_STAT8  : 0x00000668000015E4, TXX_STAT9  : 0x0000000000000000
PCS Registers:
        MRX_CTL_REG: 0x0000000000001140, MRX_STS_REG: 0x000000000000017C
        RXX_STA_REG: 0x00000000000008C7, RXX_SYN_REG: 0x0000000000000003
        TXX_STA_REG: 0x0000000000000064, SGMX_AN_ADV: 0x0000000000001801
        SGMX_AN_ADV: 0x000000000000D401, MISC_CTL   : 0x0000000000000000
        ANX_ADV_REG: 0x0000000000000060, ANX_LP_ABIL: 0x000000000000D000
        ANX_RESULTS: 0x000000000000000F, ANX_EXT_ST : 0x000000000000C000
        LNX_TMR_CNT: 0x0000000000000396, TX_RXX_PLRT: 0x0000000000000000
        INT_REG    : 0x0000000000000000, INT_EN_REG : 0x0000000000000000
        LOG_ANL_REG: 0x0000000000000000, ANX_ADV_REG: 0x0000000000000060
        ANX_LP_ABIL: 0x000000000000D000, ANX_RSL_REG: 0x000000000000000F
        ANX_EXT_ST : 0x000000000000C000, LNX_TMR_CNT: 0x0000000000000396
        MISCX_CTL: 0x0000000000001005
==============PIP Statistics================
        PIP_RX_NO_ERR = 0, PIP_PARTIAL_ERR = 0
        PIP_JABBER_ERR = 0, PIP_OVER_FCS_ERR = 0
        PIP_OVER_ERR = 0, PIP_ALIGN_ERR = 0
        PIP_UNDER_FCS_ERR = 49883, PIP_GMX_FCS_ERR = 4433
        PIP_UNDER_ERR = 0, PIP_EXTEND_ERR = 0
        PIP_LENGTH_ERR = 0, PIP_DAT_ERR = 0
        PIP_SKIP_ERR = 0, PIP_NIBBLE_ERR = 0
        PIP_UNKNOWN_ERR_14 = 0, PIP_UNKNOWN_ERR_15 = 0
        PIP_PIP_FCS = 0, PIP_PIP_SKIP_ERR = 0
        PIP_PIP_L2_MAL_HDR = 0
        pip_rx_no_particle = 0, pip_undef_err = 0
        pip_rx_no_buf_start = 0
PHY REGISTERS:
        Display for CRC check for page:6
        PACKET_GENERATION reg_addr: 16: 0x0010
        CRC COUNTERS reg_addr: 17: 0xFFFF
 Clearing CRC checker in Reg16, Page 6: Reg:16 is 0x0010
        page number:0
        Copper Contrl @ reg_addr: 0: 0x2100
        Copper Status @ reg_addr: 1: 0x7949
        PHY Idf1 @ reg_addr: 2: 0x0141
        PHY Idf2 @ reg_addr: 3: 0x0C97
        Autoneg Adv @ reg_addr: 4: 0x0D41
        Autoneg Lnk Ptr abty @ reg_addr: 5: 0x0000
        Autoneg Exp @ reg_addr: 6: 0x0004
        Autoneg Nx Pg Tx @ reg_addr: 7: 0x2801
        Autoneg Lk Prt Nx Pg @ reg_addr: 8: 0x0000
        1000B-T Ctr @ reg_addr: 9: 0x0E00
        1000B-T St @ reg_addr: 10: 0x0000
        Copper Ext St @ reg_addr: 15: 0x3000
        Copper Specific Ctl1 @ reg_addr: 16: 0x6060
        Copper Specific St1 @ reg_addr: 17: 0x6C48
        Copper Interrupt En @ reg_addr: 18: 0x0000
        Copper Specific St2 @ reg_addr: 19: 0x0440
        Copper Rcv Er Ctr @ reg_addr: 21: 0x0000
        Copper Specific Ctl2 @  reg_addr: 26: 0x8040
        page number:1
        Fiber Contrl @ reg_addr: 0: 0x1140
        Fiber Status @ reg_addr: 1: 0x7949
        Autoneg Adv @ reg_addr: 4: 0x0060
        Autoneg Nx Pg Tx @ reg_addr: 7: 0x2001
        Fiber Ext St @ reg_addr: 15: 0x3000
        Fiber Specific Ctl1 @ reg_addr: 16: 0x0000
        Fiber Specific St1 @ reg_addr: 17: 0x0018
        Fiber Interrupt En @ reg_addr: 18: 0x0000
        Fiber Specific St2 @ reg_addr: 19: 0x0000
        Fiber Rcv Er Ctr @ reg_addr: 21: 0x0000
        Fiber Specific Ctl2 @  reg_addr: 26: 0x8085
        page number:2
        MAC Contrl @ reg_addr: 0: 0x1040
        MAC Specific Ctl1 @ reg_addr: 16: 0x0288
        MAC Specific St1 @ reg_addr: 17: 0x0440
        MAC Interrupt En @ reg_addr: 18: 0x0000
        MAC Specific St2 @ reg_addr: 19: 0x0000
        MAC Specific Ctl2 @  reg_addr: 26: 0x0005
TX_COUNT: 0, TX_LIMITED: 0, TX_HEAD: 411, TX_TAIL: 411
TX_MIN_SIZE: 32, TX_MAX_SIZE: 512, TX_CURRENT_SIZE: 128
RX STARVES: 0
Software MAC Address Filter (hash:length/addr/mask/hits)
  0x000:  0  ffff.ffff.ffff  0000.0000.0000     36045
  0x0C0:  0  0180.c200.0002  0000.0000.0000         0
  0x0C0:  1  0100.0ccc.cccc  0000.0000.0000      1507
  0x0C5:  0  0180.c200.0007  0000.0000.0000         0
  0x0CC:  0  0180.c200.000e  0000.0000.0000      2702
  0x0FA:  0  00c8.8b61.5371  0000.0000.0000         0
  Software filtered frames: 36994
  Unicast overflow mode: 0
  Multicast overflow mode: 1
  Promiscuous mode: 0
  Total Number of CAM entries: 1
Port Stopped: N
Internal Loopback Set: N
Router#
Please find the details below,
This is my total router configuration
Router#sh int
Embedded-Service-Engine0/0 is administratively down, line protocol is down
  Hardware is Embedded Service Engine, address is 0000.0000.0000 (bia 0000.0000.0000)
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 02:54:38
  Input queue: 0/64/0/0 (size/max/drops/flushes); Total output drops: 0
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
GigabitEthernet0/0 is up, line protocol is up
  Hardware is CN Gigabit Ethernet, address is 00c8.8b61.5370 (bia 00c8.8b61.5370)
  Description: $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
  Internet address is 125.99.247.246/30
     reliability 255/255, txload 1/255, rxload 3/255
  Last input 00:00:00, output 00:00:00, output hang never
  5 minute input rate 1301000 bits/sec, 180 packets/sec
  5 minute output rate 124000 bits/sec, 113 packets/sec
     2697109 packets input, 3297549546 bytes, 0 no buffer
     Received 523 broadcasts (0 IP multicasts)
     12852 input errors, 6356 CRC, 6028 frame, 0 overrun, 0 ignored
     0 watchdog, 523 multicast, 0 pause input
     1663255 packets output, 239791028 bytes, 0 underruns
     349 unknown protocol drops
     reliability 254/255, txload 3/255, rxload 1/255
  5 minute input rate 130000 bits/sec, 112 packets/sec
  5 minute output rate 1300000 bits/sec, 180 packets/sec
     1655155 packets input, 242677966 bytes, 0 no buffer
     Received 5172 broadcasts (0 IP multicasts)
     109544 input errors, 54777 CRC, 50310 frame, 0 overrun, 0 ignored
     0 watchdog, 543 multicast, 0 pause input
     2693553 packets output, 3296462579 bytes, 0 underruns
     350 unknown protocol drops
GigabitEthernet0/2 is administratively down, line protocol is down
  Hardware is CN Gigabit Ethernet, address is 00c8.8b61.5372 (bia 00c8.8b61.5372)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Auto Duplex, Auto Speed, media type is RJ45
     0 watchdog, 0 multicast, 0 pause input
FastEthernet0/0/0 is up, line protocol is up
  Hardware is FastEthernet, address is c84c.75e4.0e7d (bia c84c.75e4.0e7d)
  Internet address is 10.1.95.134/30
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:15, output 00:00:00, output hang never
  5 minute input rate 5000 bits/sec, 3 packets/sec
  5 minute output rate 3000 bits/sec, 3 packets/sec
     466297 packets input, 105984447 bytes
     0 watchdog
     328599 packets output, 70246523 bytes, 0 underruns
     377 unknown protocol drops
FastEthernet0/0/1 is up, line protocol is up
  Hardware is FastEthernet, address is c84c.75e4.0e7e (bia c84c.75e4.0e7e)
  Internet address is 172.17.122.1/24
  5 minute input rate 6000 bits/sec, 5 packets/sec
  5 minute output rate 5000 bits/sec, 3 packets/sec
     341625 packets input, 71191333 bytes
     Received 6844 broadcasts (0 IP multicasts)
     560 input errors, 383 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog
     471535 packets output, 106250902 bytes, 0 underruns
NVI0 is up, line protocol is up
  Hardware is NVI
  Interface is unnumbered. Using address of GigabitEthernet0/0 (125.99.247.246)
  MTU 1514 bytes, BW 56 Kbit/sec, DLY 5000 usec,
  Encapsulation UNKNOWN, loopback not set
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
Router#
HI!
Could you please try to change if you have brand new RJ45 cable ,
pls change it .
because some time may be cable issue  will be there
and interface should be in auto mode
Duplex and Speed is AUTO
thank you
CRaju
Thank you for your Reply,
Give some time I will change the proper things and let you know.
And if I want to contact in future, How I will contact to you?
Raj
[email protected]
HI !
It should be both sides
 Duplex and Speed is AUTO.
or else it should keep both sides coded .
thank you
CRaju
Raj
[email protected]
 duplex full
 speed 100
As suspected, the line errors are caused by the hard coding of the speed and duplex settings.
FCS errors.
Then how to resolve this issue? Please help me out.
What I will do for this? what to do, what not to do?
I didn't understand what your mention below, what is my current action?
Dear Sir,
Just now only I did changes
Current configuration : 193 bytes
 ip nat inside
 duplex auto
 speed auto
end
Thank you Sir, Your my HERO.
Now G0/1 is clear, but I am getting the errors from G0/0 and fastethernet0/0/1
  Last input 00:00:01, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:17:57
  5 minute input rate 3000 bits/sec, 3 packets/sec
  5 minute output rate 2000 bits/sec, 2 packets/sec
     2789 packets input, 438845 bytes
     Received 744 broadcasts (0 IP multicasts)
     1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog
     1660 packets output, 168461 bytes, 0 underruns
     36 unknown protocol drops
     reliability 254/255, txload 1/255, rxload 2/255
  5 minute input rate 1158000 bits/sec, 114 packets/sec
  5 minute output rate 81000 bits/sec, 73 packets/sec
     159471 packets input, 194566253 bytes, 0 no buffer
     Received 54 broadcasts (0 IP multicasts)
     1033 input errors, 512 CRC, 490 frame, 0 overrun, 0 ignored
     0 watchdog, 54 multicast, 0 pause input
     97428 packets output, 16442278 bytes, 0 underruns
Then now what I will do?
Sir,
For these 2 interfaces also having the FCS problem, so shall I reset the Speed and duplex?
Raj
Hello Sir,
Please find the below details,
1.sh run int f0/0/1 and G0/0
Router# sh run int g0/0
Current configuration : 199 bytes
interface GigabitEthernet0/0
 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
 ip address 125.99.247.246 255.255.255.252
 ip nat outside
 duplex full
 speed 100
end
Router# sh run int f0/0/1
Current configuration : 98 bytes
interface FastEthernet0/0/1
 ip address 172.17.122.1 255.255.255.0
 duplex full
 speed 100
end
Router#
2.sh controll g0/0 and f0/0/1
Router#sh controll g0/0
Interface GigabitEthernet0/0
 = Hardware =
HWIDB: 218A51B0, INSTANCE: 218A5F00, FASTSEND: 300B2020, MCI_INDEX: 0
= Media  RJ45 =
PORT IPD Registers:
GMX Registers:
        RXX_PAU_DRP: 0x0000000000000000, RXX_STATS_P: 0x0000000000734AE3
        RXX_STAT_CT: 0x0000000000000000, RXX_STATS_D: 0x0000000000000269
        RXX_STAT_DR: 0x0000000000000000, RXX_STATS_B: 0x0000000000003C9C
        SMACX      : 0x000000C88B615370
        ADR_CAM5   : 0x0000000000000070
        TXX_STAT2  : 0x000000002B7F3E31, TXX_STAT3  : 0x00000000004674C5
        TXX_STAT4  : 0x001B596E00000000, TXX_STAT5  : 0x0001BDF00022601F
        TXX_STAT6  : 0x00024F520001E603, TXX_STAT7  : 0x000000000002C7F3
        TXX_STAT8  : 0x00000DCD00000004, TXX_STAT9  : 0x0000000000000000
PCS Registers:
        PIP_UNDER_FCS_ERR = 1863, PIP_GMX_FCS_ERR = 91
PHY REGISTERS:
        page number:0
        Copper Specific St1 @ reg_addr: 17: 0x6C08
        Copper Specific St2 @ reg_addr: 19: 0x0400
        page number:1
        page number:2
TX_COUNT: 0, TX_LIMITED: 0, TX_HEAD: 197, TX_TAIL: 197
RX STARVES: 0
  0x000:  0  ffff.ffff.ffff  0000.0000.0000         0
  0x0C0:  1  0100.0ccc.cccc  0000.0000.0000      4551
  0x0CC:  0  0180.c200.000e  0000.0000.0000         0
  0x0FB:  0  00c8.8b61.5370  0000.0000.0000         0
  Software filtered frames: 48554
  Promiscuous mode: 0
Port Stopped: N
Router#sh controll f0/0/1
Interface FastEthernet0/0/1
 HWIC Registers
 Status = 0x2700            Control = 0x335
Intr Event= 0x1     SMI Spd = 0x6
Marvell switch registers=0x10000800
Number of Packets received with errors:
Bad Marvell Trailer: 0   Packets received
Marvell PHY (1) Register:
Reg 29 = 0x1000087A         Reg 30 = 0x1000087C
Control    : 0x2100         Status      : 0x7849
Identifier : 0x141  0xC89
Auto Neg   : 0x141          Auto Neg Exp: 0x4
LP Ability : 0x0            LP NxtPg    : 0x0
PHY ctrl   : 0x4130         PHY status  : 0x7C00
Intr enable: 0x400          Intr status : 0x0
Port (1) Registers:
Status     : 0x3B00         Control     : 0x77
Identifier : 0x831          Vlan Map    : 0x2200
VID and PRI: 0x2            Rate Control: 0x30
Port Asc Vt: 0x2
TX counter : 0x4B2          RX counter  : 0x5965
Port (CPU PORT=9) Registers:
Status     : 0x3A00         Control     : 0x77
Identifier : 0x831          Vlan Map    : 0x2002
Port Asc Vt: 0x200
TX counter : 0x5965         RX counter  : 0x4B5
 Software MAC address filter(hash:length/addr/mask/hits):
  0x00:  0  ffff.ffff.ffff  0000.0000.0000     49499
  0x0B:  0  c84c.75e4.0e7e  0000.0000.0000   1424907
  0xC0:  0  0180.c200.0002  0000.0000.0000         0
  0xC0:  1  0100.0ccc.cccc  0000.0000.0000      1715
  0xC5:  0  0180.c200.0007  0000.0000.0000         0
  0xCC:  0  0180.c200.000e  0000.0000.0000      3047
ATU table:
   Mac Address     |   Ports   |  Entry State  | dbnum
FE unit = 0
Counters Names Port=1, CPU_PORT=9
        InUnicasts      = 1427459, 1834358
        InBroadcasts    = 49617, 3
        InPause         = 0, 0
        InMulticasts    = 53137, 1852
        InFCSErr        = 1805, 0
        AlignErr        = 0, 0
        InGoodOctets    = 317649303, 406732165
        InBadOctets     = 298049, 0
        Undersize       = 0, 0
        Fragments       = 734, 0
        In64Octets      = 84568, 69668
        In127Octets     = 77636, 16493
        In255Octets     = 1332252, 1719779
        In511Octets     = 28362, 16073
        In1023Octets    = 7667, 1598
        InMaxOctets     = 1533, 12602
        Jabber          = 0, 0
        Oversize        = 0, 0
        InDiscards      = 0, 0
        Filtered        = 0, 0
        OutUnicasts     = 1834356, 1427459
        OutBroadcasts   = 2, 49617
        OutPause        = 0, 0
        OutMulticasts   = 1852, 53137
        OutFCSErr       = 0, 0
        OutGoodOctets   = 406731973, 317649303
        Out64Octets     = 69665, 84558
        Out127Octets    = 16493, 76976
        Out255Octets    = 1719779, 1331153
        Out511Octets    = 16073, 28338
        Out1023Octets   = 1598, 7657
        OutMaxOctets    = 12602, 1531
        Collisions      = 0, 0
        Late            = 0, 0
        Excessive       = 0, 0
        Multiple        = 0, 0
        Single          = 0, 0
        Deferred        = 0, 0
        OutDiscards     = 3, 0
FPGA Buffer Descriptors: 0x10000150
tx_bd_head     = 53
tx_bd_tail     = 53
mac_dma_ctrl   = 0x800C
mac_dma_status = 0x0
rx_bd_base     = 0xE968800
rx_bd_tail     = 37
rx_bd_head     = 37
rx_bd_Q_size   = 64
Sizes of Tx and Rx rings:
ds->tx_ring_entries   = 128
ds->rx_ring_entries   = 64
IOS DS descriptor counters:
ds->tx_head    = 53
ds->tx_tail    = 53
ds->tx_count   = 0
ds->rx_head    = 37
ds->rx_tail    = 37
Router#
