ip range acl
faizkarimullah baig
Community Member
hi
in lan we use subnet 10.10.16.0/22 ,from 10.10.16.1 to 10.10.18.200 is using and remaining we want to block in router using acl
                        how can i configure router plz suggest me
Hi Faiz,
Please provide more info the question is bit confusing
please provide a network diagram is possible
Zeeshna
Hi zeeshna ,
    a).  in lan we use a subnet 10.10.16.0/22 means ip range from 10.10.16.1 to 10.10.19.254 .
     b) we assgined ips to nodes from 10.10.16.1 to 10.10.18.200.
      c)remaining ips means 10.10.18.201 to 10.10.19.254 is assgined to any nodes by manually ,that nodes traffic should be rejected by router
    means as far as i know i configure acl using host or network, can i configure acl ips range like to allow 10.10.16.1 to 18.200 by router and remaing ips block.
    Faiz
No you cannot specify address ranges like this.
You specify address blocks using wildcard masks in ACLs along with hosts.
You can split it like
10.10.16.0/23 10.10.16.0 - 10.10.17.255
10.10.18.0/25 10.10.18.0 - 10.10.18.127
10.10.18.128/26 10.10.18.128 - 10.10.18.191
10.10.18.192/29 - 10.10.18.192 - 10.10.18.199
10.10.18.200/32
This should be sufficient for you to use.
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
