03-17-2013 06:41 PM - edited 03-07-2019 12:17 PM
Where is the "ip routing" command in Cisco switch 6500 series?
is the ip routing enable by default accoridng to the:
https://supportforums.cisco.com/docs/DOC-3897
Siavash
03-17-2013 06:48 PM
That is correct. IP routing is enabled by default on the 6500 series.
03-17-2013 09:08 PM
Thank you
03-17-2013 06:52 PM
Yes its enabled by default.
Inayath
