IP Routing Issue on C3750 - unable to apply route map IP Policy
Waqas Butt
I have an issue with C3750 to add a route map for VLAN 1, the image is: c3750-ipservicesk9-mz.122-50.SE2.bin
..... my internal clients having issue to access pop3 (995) ....> The Firewall PIX 525 is the gateway... which allows the protocol.
Can anyone advise.
Waqas
InayathUlla Sharieff
Since it is 3750, make sure you are running the IP services image and have routing SDM. You can check that with "show version" and "show sdm prefer" correspondingly.
To change SDM template (note that reload is required):
     conf t
          sdm prefer routing
          end
     reload
Inayath
**Please rate this post if you find it usefull
     conf t
          sdm prefer routing
          end
     reload
Inayath
Thanks.... Its worked.... i am able to add route map to VLAN now...
Waqas
