IP Routing on 3550
ddaugherty1264
Starting point: 8-3550 Switches, 1-2811 router (10.2.232.250), all on one subnet 10.2.232.0:255.255.252.0, one VLAN=1. ALL WORKS FINE.
I'm adding VLANs and I need to enable routing on the switches for Inter-VLAN routing. However, when I enable ip routing on the frist switch, the 'network' still works (stations work fine) however, in about 3 minutes, I can no longer HTTP nor ping the VLAN 1 interface. I'm guessing the 3 min delay is routing info updating. I can't even reach it on the switch itself. So, I can't manage it in Network Assistant, nor the web interface. I can still get to any other switch VLAN interface.
Here is before conf info:
no ip subnet-zero
no file verify auto
spanning-tree mode pvst
spanning-tree portfast default
vlan internal allocation policy ascending
interface Vlan1
ip address 10.2.232.203 255.255.252.0
ip default-gateway 10.2.232.250
ip classless
ip http server
Here is after:
no ip subnet-zero
ip routing
no file verify auto
interface Vlan1
ip classless
ip route 0.0.0.0 0.0.0.0 10.2.232.250
ip http server
This driving me crazy and not a good experience with ip routing on the 3550. It probably comes down to me misconfiguring something, but I don't know what.
Please assist and I will be singing praises about you!
Thanks.
29 Replies 29
Correct. Once the routing process is enabled IP default gateway no longer functions.
I'm wondering why "no IP subnet-zero" is enabled and why all the switch ports are set to dynamic desirable, but that is really neither here nor there.
What does the output of "show ip route" provide?
What is the default gateway of your client machines?
Have you fixed this problem? looking at the posts on this it does not address the problem
has your 3550 have EMI or SMI IOS loaded that determines whether you could do L3 switching otherwise
You do your L3 routing on the 2811
create subinterfaces on the etherner ports
trunk to the switches, then on the switch ports use the "Switchport access vlan" command to select the required vlan
ecornwell
Level 2
Level 2
I was wondering if anyone has made any headway on this. We just put a 3550 in service and ran into the same problem.
I've got a very similar setup. I was working in the switch earlier today when this problem happened. I turned off ip routing and reloaded. Everything worked fine. I was able to pass a little data with the switch configured without routing but DHCP wouldn't work. I turned on ip routing and DHCP started working. A little while later my telnet session was closed and when I tried to reconntect the switch wouldn't respond.
I've got the latest code as of today loaded on the switch and still no luck.
can you pl. post the config
regards
param
version 12.2
no service pad
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
hostname SWITCH
enable secret ********************
no aaa new-model
clock timezone EST -5
clock summer-time EST recurring
ip subnet-zero
ip routing
no file verify auto
interface FastEthernet0/1
descr Currenlty used Port
switchport mode trunk
interface FastEthernet0/2
switchport mode dynamic desirable
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
descr PORT NO LONGER USED
interface Vlan1
ip address 1.1.0.10 225.255.252.0
interface Vlan60
ip address 1.2.0.1 255.255.252.0
ip helper-address 1.1.0.2
interface Vlan61
ip address 1.3.0.1 255.255.252.0
interface Vlan62
ip address 1.4.0.1 255.255.252.0
ip default-gateway 1.1.0.1
ip classless
ip route 0.0.0.0 0.0.0.0 1.1.0.1 permanent
ip http server
ip http secure-server
control-plane
ntp server 1.1.0.1
end
I changed a few things to hide addresses and stuff.
All - I got tired of messing with this. My guess is there is a bug in the IOS version. I configured a 'router on a stick', and all works as expected.
That's too bad... I was afriad that would happen.
What exactly is a 'router on a stick?'
I had a similar issue with a 3550 switch. I opened a TAC case and was told to remove the MLS entries. Unfortunately I changed jobs before this could get implemented.
rseiler
Level 3
Level 3
You were only doing this on *ONE* 3550 switch, right? Not all 8? You would only need to do the ip routing on *ONE* (core?) 3550 switch and cannot have *ANY* other switches configured for routing without a much more complicated config.
Just checking. You sent one config but I would be interested in the config of the other 7 switches.
I have had *ZERO* issues with the Cisco 3550 switch for IP routing over the last 5 years...
Let me know if you would like to troubleshoot this further...
I would love to get this working. We only have one layer 3 switch in this network and it was purchased to do vlan routing. Do you see anything wrong with the config I posted? I've followed the documents I found and the switch is setup almost the exact same way.
I'm more interested in the config of the other 7 switches. How are they connected and configured?
That wasn't me that posted that, I'm just having the exact same problem. The 3550 is the only layer 3 switch we have in that network. All other switches are connected through 802.1q trunks.
Have you tried using vlan 1 as the native vlan for all trunks on connected switches?
vlan 1 or your management vlan should be used.
This should solve your issue. Each switch should have an dot1q trunk w/VLAN1 configured as the native vlan. This way your trunks will always pass traffic and you should be able to communicate with your switches (vty) on the configured vlan1 address.
I'm not really sure what you're asking. Typically we don't change the native vlan on the switch.
We configure all switches for 802.1q trunks and we haven't had any problems at our main facility. We have used a very similar config on a 3750 and it works without and problems at another facility.
The really strange thing is that it works for a little while then just stops responding.
rll3
just for kicks... how was the router configured that connected to this switch?
did it have subinterfaces?
