ip routing question
avionics
if anyone could explain why my to all my interfaces wont ping each other??? i attached the configuration. i am at a loss don't understand why it wont work.
mounir.mohamed
Level 7
Level 7
Which interfces not pinable, the only interface has an IP address is the BVI, could you explane your issue more.
First, IP nat configurations shoudl be placed under the Layer 3 interface which is the BVI interface in your case.
Remove the NAT configurations and test it.
Pls rate helpful posts.
Best Regards,
Mounir Mohamed
