IP SLA configuration issue
BernardNdale
Community Member
I am running c800-universalk9-mz.SPA.157-3.M.bin on cat800 router and need help how to configure IP SLA.
cause it seems like Ip Sla monitor command is not supported.
Please help
balaji.bandi
Can you post-show the version of the device?
BB
Georg Pauwen
as far as I recall, the 'ip sla monitor' command was available in pre 12.4 versions, after that, it has been replaced by 'ip sla operation_number.
balaji.bandi
ignore my comments earlier, i was in impress it was not working ip sla configuriaton, looks like you looking to monitor (but is the IP sla configuraiton accepted ) ?
here is syntax to use for monitor :
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipsla/configuration/15-mt/sla-15-mt-book/sla_icmp_echo.html
BB
