IP SLA probes between 2900 (15.0) and 2800 (12.4)
I've problem with IP SLA probes between two different routers.
2900 (c2900-universalk9_npe-mz.SPA.151-4.M4.bin) here is set "ip sla responder" only
and
2800 (c2800nm-advipservicesk9-mz.124-24.T2.bin) here is set two type of tests "udp-jitter" and "icmp-jitter" - temporary, used to check for availability of 2900 router.
As a result, I've what udp-jitter doesn't work at the same time icmp-jitter test is OK.
Here are the settings of IP SLA tests
ip sla 281
icmp-jitter 172.25.28.1 source-ip 192.168.28.6 num-packets 100
tos 128
frequency 120
ip sla schedule 281 life forever start-time after 00:05:45
ip sla 284
udp-jitter 172.25.28.1 28287 source-ip 192.168.28.6 num-packets 100
tos 128
frequency 120
ip sla schedule 284 life forever start-time after 00:06:00
clock works correctly on both routers,
I've trying to setup "ip sla responder udp-echo port 28287" on 2900 router, but this has no effect.
2800#sh ip sla statistics 281
IPSLAs Latest Operation Statistics
IPSLA operation id: 281
Type of operation: icmp-jitter
        Latest RTT: 11 milliseconds
Latest operation start time: 10:06:25.266 MSK Fri Apr 12 2013
Latest operation return code: OK
RTT Values:
        Number Of RTT: 100              RTT Min/Avg/Max: 11/11/13
Latency one-way time:
        Number of Latency one-way Samples: 23
        Source to Destination Latency one way Min/Avg/Max: 12/12/13
        Destination to Source Latency one way Min/Avg/Max: 1/1/1
Jitter Time:
        Number of SD Jitter Samples: 99
        Number of DS Jitter Samples: 99
        Source to Destination Jitter Min/Avg/Max: 0/1/1
        Destination to Source Jitter Min/Avg/Max: 0/1/1
Packet Late Arrival: 0
Out Of Sequence: 0
        Source to Destination: 0        Destination to Source 0
        In both Directions: 0
Packet Skipped: 0       Packet Unprocessed: 0
Packet Loss: 0
        Loss Period Length Min/Max: 0/0
Number of successes: 7
Number of failures: 0
Operation time to live: Forever
2800#sh ip sla statistics 284
IPSLA operation id: 284
Type of operation: udp-jitter
        Latest RTT: NoConnection/Busy/Timeout
Latest operation start time: 10:06:40.522 MSK Fri Apr 12 2013
Latest operation return code: Timeout
RTT Values:
        Number Of RTT: 0                RTT Min/Avg/Max: 0/0/0 milliseconds
        Number of Latency one-way Samples: 0
        Source to Destination Latency one way Min/Avg/Max: 0/0/0 milliseconds
        Destination to Source Latency one way Min/Avg/Max: 0/0/0 milliseconds
Jitter Time:
        Number of SD Jitter Samples: 0
        Number of DS Jitter Samples: 0
        Source to Destination Jitter Min/Avg/Max: 0/0/0 milliseconds
        Destination to Source Jitter Min/Avg/Max: 0/0/0 milliseconds
Packet Loss Values:
        Loss Source to Destination: 0           Loss Destination to Source: 0
        Out Of Sequence: 0      Tail Drop: 0
        Packet Late Arrival: 0  Packet Skipped: 0
Voice Score Values:
        Calculated Planning Impairment Factor (ICPIF): 0
        Mean Opinion Score (MOS): 0
Number of successes: 0
Number of failures: 7
2900#sh ip sla respo
        General IP SLA Responder on Control port 1967
General IP SLA Responder is: Enabled
Number of control message received: 5113 Number of errors: 0
Recent sources:
        192.168.28.6 [10:26:40.537 MSK Fri Apr 12 2013]
        172.23.0.252 [10:26:18.125 MSK Fri Apr 12 2013]
        172.23.0.254 [10:26:16.361 MSK Fri Apr 12 2013]
        172.23.0.254 [10:26:14.817 MSK Fri Apr 12 2013]
        172.23.0.254 [10:26:12.825 MSK Fri Apr 12 2013]
Recent error sources:
        Permanent Port IP SLA Responder
Permanent Port IP SLA Responder is: Enabled
udpEcho Responder:
  IP Address             Port
  0.0.0.0               28287
  ::                    28287
Thank for advice!
Steve Fuller
Level 9
Level 9
Can you post the IP SLA configuration from the Cisco 2900 router? I never normally specify the port on the responder, so leaving it to the IP SLA control protocol to negotiate and communicate that between probe and responder.
Also are you able to run debug ip sla error 0 on the IP SLA responder and post that output here?
Configuration from 2900 router are below.
I've turned on debug, and here are no any errors.
2900#sh run | i ip sla
ip sla responder
2900#deb ip sla err 0
2900#term mon
2900#
2900#
Number of control message received: 7335 Number of errors: 0
Recent sources:
172.23.0.252 [14:41:20.692 MSK Sat Apr 13 2013]
172.23.0.254 [14:41:18.984 MSK Sat Apr 13 2013]
172.23.0.254 [14:41:17.392 MSK Sat Apr 13 2013]
172.23.0.254 [14:41:15.400 MSK Sat Apr 13 2013]
192.168.28.6 [14:40:42.200 MSK Sat Apr 13 2013]
Permanent Port IP SLA Responder is: Disabled
There are errors in the messages of 2800 router debug.
2800#deb ip sla error 284
IP SLA ERROR debugging for entry 284 is on
2800#
Apr 13 10:53:07.213: IP SLAs(284) jitter operation: Interval Timer invoked 1088 times Packets not sent out 14 times
Apr 13 10:57:07.221: IP SLAs(284) jitter operation: Interval Timer invoked 1188 times Packets not sent out 1 times
This may be related to the license of 2900 router?
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
In the opposite direction test works correctly.
