ip snooping will disable all dhcp traffic on a 2960 PT switch
keesepema
I want to be certain about ip dhcp snooping configuration on a Cisco 2960 switch (in Packet Tracer)
Is it true that ip dhcp snooping will disable all dhcp traffic on all the switchports of a 2960 PacketTracer switch?
So if that is true, enabling ip dhcp snooping trust on a switchport, will allow dhcp traffic for that switchport.
Is my understanding of dhcp snooping right?
balaji.bandi
When dhcp snooping is enabled, the default trust setting for interfaces is untrusted,  so if you need you should apply ip dhcp snooping trust on interfaces leading to where your dhcp server is located.
BB
balaji.bandi
BB
