IP Source Guard Cause Cisco IP phone lost connection
jason_majie
Hi All:
recently, i have deployed some new 2960 stackable switch to replace 3750 switches(will be used in other location),
I enabled IP dhcp snooping, DAI and IPSG feature, some as previous configuration in 3750 switches.
I found some strange behavior.
I turned on IP dhcp snooping first, and run for a few days to make sure the switch has the binding entry for every clients/ip phone, (i manually reset the phone), then i enable DAI for data vlan and voice vlan, everything works fine.
finally, i enable IPSG, the ip phone with PC attached behind works fine, but some ip phones without pc attached lost connection and screen shows registering. i check the switch IPSG info, it shows
2960PT_21FLR_ES01#show ip verify source
Interface  Filter-type  Filter-mode  IP-address       Mac-address        Vlan
Gi1/0/21   ip           active       10.167.153.112                      53
Gi1/0/21   ip           active       deny-all                                 34
Gi1/0/40   ip           active       10.167.153.116                      53
Gi1/0/40   ip           active       deny-all                                 34
Gi1/0/41   ip           active       10.167.153.166                      53
Gi1/0/41   ip           active       10.167.134.103                      34
Gi2/0/7    ip           active       10.167.153.160                      53
Gi2/0/7    ip           active       10.167.134.164                      34
[voice vlan 34, data vlan 53]
Gi1/0/21 is connecting to a phone without PC attached, and the phone works fine.
Gi1/0/40 is also connecting to a phone without PC attached, and lost connection immediately.
once i disable the IPSG at the respective port (gi1/0/40), the phone returns to normal.
--------switch configuration-----------
ip dhcp snooping vlan 34,53
no ip dhcp snooping information option
ip dhcp snooping database flash:dhcpsnooping.dat
ip dhcp snooping database write-delay 15
ip dhcp snooping
ip arp inspection vlan 34,53
interface GigabitEthernet1/0/40
switchport access vlan 34
switchport mode access
switchport voice vlan 53
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
service-policy input AutoQoS-Police-CiscoPhone
ip dhcp snooping limit rate 10
any one encountered the some problem before? any suggestion?
thanks a lot
I have tried the version 12.2(55)SE1. This version is working properly.
Aliaksandr
11 Replies 11
APatotski
I have the same issue with IPSG. But in my case the IP phone and PC loose connection when PC is connected trough the phone. I'm using 2960S with 12.2.55SE. When the PC or phone are connected to switch separatly every thing is working fine. I have not found the solution yet.
APatotski
I have consulted with Cisco TAC. They ansvered that this issue is related to the following bugs CSCtj11377
and CSCtj59404.
The workaround is to reload the switch. I have tried this and the IPSG is working properly after reload. But the issue arise again after disabling and enabling IPSG on the interface. I have desided to not using IPSG in production before the bug will be fixed.
Hi Apatotski:
I searched the bug id and found it was
Fixed-In                                                          Fixed-in
12.2(55)SE1
have you tried these version?
btw, my switch is running of 12.2(55)SE version but still got the same problem.
thanks for your answer.
regards
I have not tried this version yet. I will try and inform you about the results.
I have found that 12.2(55)SE1 is not published yet for download. So we need to wait when this version will be published.
Dear Cisco Stars,
I do have the same issue with all my 250 New IP Phones connected on stacked 3750. I am currently running 12.2 53 SE2.
When i remove IPSG, the IP Phone works fine.
Please keep us posted with any possible developments..
Thanks a lot
Jafy
hi :
12.2(55)SE1works fine.
thanks
hi Apatotski:
merry x'mas~~
The version 12.2(55)se1 are available for downloading, you manage to find a chance to try it out??
please let me know, thanks a lot~~
regards
Jason
I have not tried it. I will try and keep you updated.
Aliaksandr
just roll out this version on a small site, so far it works fine.
Some laptop/PCs were not able to work, i just did a ipconfig/release & renew, then they started to work.
thanks
