IP source guard traffic dropped
thedax
Hi everyone,
I'm trying to configure, on GNS3, the DHCP snooping+IPSG, the last one just for IP filtering.
Anyway, when "ip verify source" is enabled on a port, hosts traffic is dropped regardless the IP DHCP snooping table is apparently correctly filled.
Following some infos.
Switch configuraiton
adasd
version 15.2
service compress-config
hostname SW_D1
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp snooping vlan 3,5
no ip dhcp snooping information option
ip dhcp snooping
ip cef
no ipv6 cef
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/0
switchport trunk allowed vlan 3,5
switchport mode trunk
media-type rj45
negotiation auto
ip dhcp snooping trust
interface GigabitEthernet0/1
switchport access vlan 3
switchport mode access
media-type rj45
negotiation auto
ip verify source
interface GigabitEthernet0/2
switchport access vlan 5
media-type rj45
negotiation auto
ip verify source
interface GigabitEthernet0/3
media-type rj45
negotiation auto
ip verify source
interface GigabitEthernet1/0
media-type rj45
negotiation auto
ip verify source
ip forward-protocol nd
no ip http server
no ip http secure-server
# show ip verify source
SW_D1#show ip verify source
Interface  Filter-type  Filter-mode  IP-address       Mac-address        Vlan
Gi0/1      ip           active       deny-all                            3
Gi0/2      ip           active       deny-all                            5
Gi0/3      ip           active       10.0.1.22                           3
Gi1/0      ip           inactive-no-snooping-vlan
# show ip dhcp snooping
SW_D1#show ip dhcp snooping
Switch DHCP snooping is enabled
Switch DHCP gleaning is disabled
DHCP snooping is configured on following VLANs:
3,5
DHCP snooping is operational on following VLANs:
3,5
DHCP snooping is configured on the following L3 Interfaces:
Insertion of option 82 is disabled
   circuit-id default format: vlan-mod-port
   remote-id: 0c3f.f680.ab00 (MAC)
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
Verification of giaddr field is enabled
DHCP snooping trust/rate is configured on the following Interfaces:
Interface                  Trusted    Allow option    Rate limit (pps)
GigabitEthernet0/0         yes        yes             unlimited
  Custom circuit-ids:
#show ip dhcp snooping binding
SW_D1#show ip dhcp snooping binding
MacAddress          IpAddress        Lease(sec)  Type           VLAN  Interface
62:D0:C1:DC:3E:C1   10.0.1.22        6965        dhcp-snooping   3     GigabitEthernet0/3
Total number of bindings: 1
But ping doesn't works
# ping 10.0.1.1
PING 10.0.1.1 (10.0.1.1) 56(84) bytes of data.
From 10.0.1.22 icmp_seq=1 Destination Host Unreachable
From 10.0.1.22 icmp_seq=2 Destination Host Unreachable
From 10.0.1.22 icmp_seq=3 Destination Host Unreachable
 but if I cut out "ip verify source" from G0/3, ping start to works correctly.
Any ideas? Thanks in advance
10 Replies 10
run Port security in one Port with IP verify source
then check
NO need since all IP verify not work
MHM
Ty @MHM Cisco World.
I enabled port-security on a port like following but nothing change
 switchport port-security
 media-type rj45
 negotiation auto
 ip verify source
ip verify source vlan dhcp-snooping
On IOS version used there isn't that option
SW_D1(config-if)#ip verify source ?
  port-security  port security
  tracking       tracking ip device
ip verify source port-security
this and run port-security in one port and check  ping
share this
MHM
The ping doesn't work yet
SW_D1#show running-config interface G0/3
Building configuration...
Current configuration : 179 bytes
 media-type rj45
 negotiation auto
end
Gi0/3      ip-mac       active       10.0.1.22        62:D0:C1:DC:3E:C1  3
Gi1/0      ip           active       deny-all                            5
SW_D1#
If you apply Port ACL to l2 port you use and it work then it IPSG issue
If yoh apply PACL and it not work also then it gns3 limitations
IPSG work by add PACL to l2 port.
MHM
I am using the same vIOS_l2 image, it looks like it doesn't work in GNS3. Can you try static bindings (ip source binding) ? Also, make sure 'ip routing' is enabled on your switch (I think in GNS3 it is enabled by default)...
ty @Georg Pauwen .
No, I haven't tryed with static beacuse I would intersted in dynamic one, but I'll do a test with static at this point. Anyway should be my setup  correct right?  So, Could be a GNS3 issue as you already sayd?
the configs look good and this should definitely work on a 'real' switch. I am pretty sure it is a GNS3 bug...
