ip tcp adjust-mss on LAN and BVI
johnlloyd_13
Level 9
Level 9
hi all,
just a quick question, we got routers configured with LAN interface and bridged to a BVI interface.
i want to set the ip tcp adjust-mss 1420 but which port will take precedence?
my question, which port do i configure this command?
interface FastEthernet0/0.2
 description ### Corp LAN ###
 encapsulation dot1Q 2
 no ip redirects
 ip accounting output-packets
 ip nbar protocol-discovery
 ip tcp adjust-mss 1420   <<<
interface BVI2
 description ### Corp VLAN ###
 ip address 192.168.231.1 255.255.255.0
 ip flow ingress
Mike Williams
Level 5
Level 5
Since this command works at the IP layer, you will need to apply it to the routed interface. That will be BVI2 in this case. Regards, Mike
Mike Williams
Level 5
Level 5
