%IPC-SP-5-WATERMARK
belchezron
We are receiving these error messages continuosly on 2 of our 6509-E running
12.2(17d)SXB7.
Mar 19 11:32:34.941: %IPC-SP-5-WATERMARK: 801 messages pending in xmt for the port CHKPT:STANDBY SP(2050000.B) seat 2050000
Mar 19 11:39:05.760: %IPC-SP-5-WATERMARK: 801 messages pending in xmt for the port CHKPT:STANDBY SP(2050000.B) seat 2050000
Mar 19 11:40:05.849: %IPC-SP-5-WATERMARK: 801 messages pending in xmt for the port CHKPT:STANDBY SP(2050000.B) seat 2050000
Mar 19 14:59:44.850: %IPC-SP-5-WATERMARK: 801 messages pending in xmt for the port CHKPT:STANDBY SP(2050000.B) seat 2050000
Mar 19 15:03:31.236: %IPC-SP-5-WATERMARK: 801 messages pending in xmt for the port CHKPT:STANDBY SP(2050000.B) seat 2050000
Mar 19 15:23:22.280: %IPC-SP-5-WATERMARK: 801 messages pending in xmt for the port CHKPT:STANDBY SP(2050000.B) seat 2050000
Cisco Error Message Decoder explanation:
Error Message %IPC-5-WATERMARK:[dec] messages pending in [hex] for the port [chars]
[hex].[hex]
Explanation A particular IPC port is overused. An application is not draining packets quickly, which suggests that the CPU might be busy. [dec] is the number of messages pending in the IPC to be processed by the application. [chars] is the IPC port name. The first [hex] is the IPC port number, the second [hex] is the IPC seat number, and the third [hex] is the IPC index.
Recommended Action Reduce the traffic on this port to a minimal level. If the error message recurs, upgrade the system software to a release containing a fix for Cisco bug ID CSCdw74873 (watermark messages appear continuously with no traffic).
My question: According to Cisco recommended action, reduce the traffic on this port, How will I know what port is affected based on the error logs?
Also, I've looked on bug toolkit and cannot find a direct match if this is a bug for the software we got and the error message we've got. Please advise how to fix this?
5 Replies 5
belchezron
It seems like were seeing bug CSCdw74873 here. However, I cannot reduce the traffic on this port as I cannot tell which port based on the error message.
According to the note on the bug details, this bug is just a cosmetic in nature. The problem was with the ipc counters only. The buffers were not really pending.
New question: Can someone please point me to commands/documentation that will prove this is just a cosmetic bug to the customer please.
The link is not available.
I have the same issue.
I see much traffic at interlink in VSS platform.
The excesive traffic can be for a bug?
Regards.
Santiago
InayathUlla Sharieff
Hi Belchezron,
Based on the data you are hitting the following bug :
CSCdw74873
 http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCdw74873
IPC-SP-5-WATERMARK messages, with some number of messages pending, might display continuously. This is a cosmetic defect with the messages pending counter. There are no messages pending. Note that this bug is just a cosmetic in nature. The problem was with the ipc counters only. The buffers were not really pending.
Action Plan:
- upgrade the software to the latest version.
Inayath
namt
I had the same issue on 3850 with the following IOS
Switch Ports Model              SW Version        SW Image              Mode
     1 56    WS-C3850-48P       03.02.02.SE       cat3k_caa-universalk9 INSTALL
     2 56    WS-C3850-48P       03.02.02.SE       cat3k_caa-universalk9 INSTALL
     3 56    WS-C3850-48P       03.02.02.SE       cat3k_caa-universalk9 INSTALL
Jun 17 17:30:40.149: %IPC-5-WATERMARK: 3598 messages pending in xmt for the port (11900B00.4) from source seat 10900100,
Jun 17 17:31:14.158: %IPC-5-WATERMARK: 3599 messages pending in xmt for the port (11900B00.4) from source seat 10900100,
Jun 17 17:31:50.161: %IPC-5-WATERMARK: 3597 messages pending in xmt for the port (11900B00.4) from source seat 10900100,
Jun 17 17:32:23.967: %IPC-5-WATERMARK: 3599 messages pending in xmt for the port (11900B00.4) from source seat 10900100,
Jun 17 17:32:58.158: %IPC-5-WATERMARK: 3597 messages pending in xmt for the port (11900B00.4) from source seat 10900100,
Jun 17 17:33:33.970: %IPC-5-WATERMARK: 3597 messages pending in xmt for the port (11900B00.4) from source seat 10900100,
Jun 17 17:34:08.159: %IPC-5-WATERMARK: 3598 messages pending in xmt for the port (11900B00.4) from source seat 10900100,
Jun 17 17:34:43.970: %IPC-5-WATERMARK: 3599 messages pending in xmt for the port (11900B00.4) from source seat 10900100,
Jun 17 17:35:18.159: %IPC-5-WATERMARK: 3597 messages pending in xmt for the port (11900B00.4) from source seat 10900100,
Jun 17 17:35:53.970: %IPC-5-WATERMARK: 3597 messages pending in xmt for the port (11900B00.4) from source seat 10900100,
I upgraded to the latest Stable Release 3.3.5.SE
Switch#software install file flash:cat3k_caa-universalk9.SPA.03.03.05.SE.150-1.EZ5.bin switch 1-3
Switch#reload
This cleared all the %IPC-5-WATERMARK.
