Iperf3 and how to show actual bandwidth usage on a switch (Catalyst 2960 or 3750)
Fab
Hi everybody,
i use "iperf3" to see the speed of a switch (not only made by Cisco), putting 2 pc to both the side of the switch.
Is there a way to see also the total used bandwidth of a switch, in a specific time?
My goal is to see if a switch's bandwidth is satured or if there is a particular port which is using it a lot.
Many thanks.
Reza Sharifi
Not sure about specific time, but you get the average switch percentage utilization by using this command:
sh controllers utilization
"sh controllers utilization" shows all zeroes!
This is the only command I found with this explanation:
"Switch Bandwidth Utilization"
