iprouting.iosproc process going high after 2 hours in WS-C6509-E ( WS-SUP720-3B)
jithu murickal
hi All,
We observed a CPU spike after every 2 hours in core switch. During the high utilization, iprouting.iosproc  is going high, we are running with s72033-advipservicesk9_wan-vz.122-33.SXI1.bin
Does any one know what will be the trigger for high utilization for iprouting.iosproc process
and the detailed output as below,
ABC #
                  Job Id: 76
                     PID: 16432
         Executable name: iprouting.iosproc
         Executable Path: sbin/iprouting.iosproc
             Instance ID: 1
                 Respawn: ON
           Respawn count: 1
Respawn since last patch: 1
  Max. spawns per minute: 30
            Last started: Sat May 11 02:26:30 2013
           Process state: Run
Process Redundancy State: Active
            Feature name: iprouting
                    Core: SHAREDMEM MAINMEM
               Max. core: 0
                   Level: 100
               Mandatory: ON
     Last restart userid:
       Related Processes:
PID    TID  Stack pri state       Blked  HR:MM:SS:MSEC FLAGS    NAME
16432  2      40K  10 Receive     1       5:04:21:0385 00000000 iprouting.iospro
16432  3      40K  10 Receive     1     125:49:07:0556 00000000 iprouting.iospro
16432  4      40K  11 Nanosleep           0:27:29:0984 00000000 iprouting.iospro
16432  5      40K  10 Receive     1     118:22:44:0233 00000000 iprouting.iospro
16432  6      40K  10 Receive     1      12:39:15:0877 00000000 iprouting.iospro
16432  7      40K  10 Receive     7       0:00:00:0000 00000000 iprouting.iospro
16432  8      40K  10 Receive     1     115:27:50:0019 00000000 iprouting.iospro
16432  9      40K  10 Receive     1      34:20:43:0873 00000000 iprouting.iospro
Thank you.
Fernando Puga
Hi jithumurickal,
I have this problem too, some advice? I saw you had this problem 8 months ago, did you found the solution?
