01-17-2014 04:15 AM - edited 03-07-2019 05:37 PM
I have configured one IPSec VPN (dgcx 1 : ip 94.200.168.198)on router c1900.and it is succefuuly working.
I also configured second IPSec VPN (dgcx 2 : ip 120.63.208.231) instance on same router and remote side having sonicwall firewall.But the VPN connection is not able to established.
At remote side packets are showing as transmited but not received from using IPSec peer ip address.Also we have check debug on our cisco router, but there is no traffic for remote ip.
we have bind the crypto map on external interface, but i dont know why traffic is not showing for dgcx 2 : ip 120.63.208.231.Traffic is only showing for dgcx 1 : ip 94.200.168.198.
Pls find the below config and debug..
Config:::::
ip multicast-routing
no ip domain lookup
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
lifetime 28800
crypto isakmp key ***** address 94.200.168.198
crypto isakmp key ***** address 203.199.49.123
crypto ipsec security-association lifetime seconds 28800
crypto ipsec transform-set dgcxset esp-3des esp-sha-hmac
crypto map dgcx 1 ipsec-isakmp
set peer 94.200.168.198
set transform-set dgcxset
set pfs group2
match address 110
crypto map dgcx 2 ipsec-isakmp
set peer 203.199.49.123
match address 120
interface Tunnel66
description To DGCX
ip unnumbered GigabitEthernet0/0
ip pim sparse-mode
ip igmp join-group 239.140.255.255
tunnel source 203.199.49.123
tunnel destination 94.200.168.198
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description 10.30.30.126 7250
ip address 203.199.49.123 255.255.255.128
ip pim sparse-mode
duplex auto
speed auto
crypto map dgcx
interface GigabitEthernet0/1
no ip address
ip pim sparse-mode
duplex auto
speed auto
interface GigabitEthernet0/1.1
description "DGCX"
encapsulation dot1Q 165
ip address 10.228.66.1 255.255.255.224
ip pim sparse-mode
ip igmp join-group 239.130.255.255
ip igmp join-group 239.120.255.255
ip igmp join-group 239.110.255.255
interface GigabitEthernet0/1.2
description "MGMT"
encapsulation dot1Q 71
ip address 10.228.1.48 255.255.255.192
interface GigabitEthernet0/1.3
description USE-VPN
encapsulation dot1Q 515
ip address 192.168.255.121 255.255.255.248
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
ip pim rp-address 10.30.30.1
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 203.199.49.1
ip route 10.30.30.0 255.255.255.0 Tunnel66
ip route 10.228.1.0 255.255.255.0 10.228.1.1
access-list 110 permit ip host 203.199.49.123 host 94.200.168.198
access-list 120 permit ip host 203.199.49.123 host 120.63.208.231
access-list 120 permit ip any host 120.63.208.231
access-list 120 permit ip 10.228.0.0 0.0.255.255 192.168.11.0 0.0.0.255
control-plane
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input all
scheduler allocate 20000 1000
end
Debugg:
DGCX#debug crypto isakmp
Crypto ISAKMP debugging is on
DGCX#debug crypto ips
Jan 17 17:37:01: ISAKMP (1625): received packet from 94.200.168.198 dport 500 sport 500 Global (R) QM_IDLE
Jan 17 17:37:01: ISAKMP: set new node 1220246999 to QM_IDLE
Jan 17 17:37:01: ISAKMP:(1625): processing HASH payload. message ID = 1220246999
Jan 17 17:37:01: ISAKMP:(1625): processing NOTIFY DPD/R_U_THERE protocol 1
spi 0, message ID = 1220246999, sa = 0x27EE81C4
Jan 17 17:37:01: ISAKMP:(1625):deleting node 1220246999 error FALSE reason "Informational (in) state 1"
Jan 17 17:37:01: ISAKMP:(1625):Input = IKE_MESG_FROM_PEER, IKE_INFO_NOTIFY
Jan 17 17:37:01: ISAKMP:(1625):Old State = IKE_P1_COMPLETE New State = IKE_P1_COMPLETE
Jan 17 17:37:01: ISAKMP:(1625):DPD/R_U_THERE received from peer 94.200.168.198, sequence 0x1E7953
Jan 17 17:37:01: ISAKMP: set new node 2086090381 to QM_IDLE
Jan 17 17:37:01: ISAKMP:(1625):Sending NOTIFY DPD/R_U_THERE_ACK protocol 1
spi 693907840, message ID = 2086090381
Jan 17 17:37:01: ISAKMP:(1625): seq. no 0x1E7953
Jan 17 17:37:01: ISAKMP:(1625): sending packet to 94.200.168.198 my_port 500 peer_port 500 (R) QM_IDLE
Jan 17 17:37:01: ISAKMP:(1625):Sending an IKE IPv4 Packet.
Jan 17 17:37:01: ISAKMP:(1625):purging node 2086090381
Jan 17 17:37:01: ISAKMP:(1625):Input = IKE_MESG_FROM_PEER, IKE_MESG_KEEP_ALIVE
Crypto IPSEC debugging is on
DGCX#
Jan 17 17:37:06: ISAKMP (1625): received packet from 94.200.168.198 dport 500 sport 500 Global (R) QM_IDLE
Jan 17 17:37:06: ISAKMP: set new node -1021258304 to QM_IDLE
Jan 17 17:37:06: ISAKMP:(1625): processing HASH payload. message ID = 3273708992
Jan 17 17:37:06: ISAKMP:(1625): processing NOTIFY DPD/R_U_THERE protocol 1
spi 0, message ID = 3273708992, sa = 0x27EE81C4
Jan 17 17:37:06: ISAKMP:(1625):deleting node -1021258304 error FALSE reason "Informational (in) state 1"
Jan 17 17:37:06: ISAKMP:(1625):Input = IKE_MESG_FROM_PEER, IKE_INFO_NOTIFY
Jan 17 17:37:06: ISAKMP:(1625):Old State = IKE_P1_COMPLETE New State = IKE_P1_COMPLETE
Jan 17 17:37:06: ISAKMP:(1625):DPD/R_U_THERE received from peer 94.200.168.198, sequence 0x1E7954
Jan 17 17:37:06: ISAKMP: set new node -609773696 to QM_IDLE
Jan 17 17:37:06: ISAKMP:(1625):Sending NOTIFY DPD/R_U_THERE_ACK protocol 1
spi 693907840, message ID = 3685193600
Jan 17 17:37:06: ISAKMP:(1625): seq. no 0x1E7954
Jan 17 17:37:06: ISAKMP:(1625): sending packet to 94.200.168.198 my_port 500 peer_port 500 (R) QM_IDLE
Jan 17 17:37:06: ISAKMP:(1625):Sending an IKE IPv4 Packet.
Jan 17 17:37:06: ISAKMP:(1625):purging node -609773696
Jan 17 17:37:06: ISAKMP:(1625):Input = IKE_MESG_FROM_PEER, IKE_MESG_KEEP_ALIVE
Jan 17 17:37:07: ISAKMP:(1625):purging node -163359897
Jan 17 17:37:12: ISAKMP:(1625):purging node -513894353
DGCX#u all
Thanx..
01-20-2014 07:33 AM
Based on what you have posted here there is inconsistency in the configuration that is probably the source of your problem. It shows that the second peer is 203.199.49.123. But this address is the address of the Gig0/0 interface of the router. How can the router peer with itself?
Rick
