catalyst 4507R-E module WS-X4648-RJ45V+E problem
hfb5
Community Member
Hi Community, I have a catalyst 4507R-E and I put this module WS-X4648-RJ45V+E in the 7 slot, but the show module command show me Unsupported, this is the show version and the show module!
? This catalyst 4507R-E whit this Supervisor Supervisor II+ WS-X4013+ suppourt thos module WS-X4648-RJ45V+E ?
thanks Community.
Sw_Core_AECSA#sh version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASE-M), Version 12.2(54)SG1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 27-Jan-11 11:43 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11ED6EBC
ROM: 12.2(31r)SGA1
Dagobah Revision 226, Swamp Revision 34
Sw_Core_AECSA uptime is 4 hours, 15 minutes
Uptime for this control processor is 4 hours, 15 minutes
System image file is "bootflash:cat4500-ipbase-mz.122-54.SG1.bin"
cisco WS-C4507R-E (MPC8245) processor (revision 10) with 262144K bytes of memory.
Processor board ID FOppp
PC8245 CPU at 266Mhz, Supervisor II+
Last reset from PowerUp
1 Virtual Ethernet interface
8 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Mod Ports Card Type                              Model              Serial No.
1     6  SFP, 10/100/1000BaseT (RJ45)V, Cisco/I WS-X4506-GB-T      JA12345
3     2  Supervisor II+ 1000BaseX (GBIC)        WS-X4013+          J12345
7     0  Unsupported module                     WS-X4648-RJ45V+E   J12345
Jon Marshall
No, your supervisor only supports classic linecards but the WS-4648-RJ45V+E is not a classic line card so it is not supported. Have a look at this link and refer to Table 1 which shows which supervisors you could use with this card -
http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea.html
Jon
Jon Marshall
Jon
Thanks, Jon!
