IPTV client interface speed require
rashad.exe
hi for all :
please any one can help me if the interface speed 100 Mb/s it's enough for IPTV client
the clients connected to access switch WS-C2960+48PST-S ,
thanks
2 Accepted Solutions
Reza Sharifi
100 Mbps is more than enough.
I think, you will be fine with 1Gig uplink, even if it is 16mb 20x16=320mb
8 Replies 8
Reza Sharifi
thanks Reza for your answer
and what about the uplink 1G for 20 IPTV clients also it's enough or i have risk
(HD channel Need from 8 to 10 Mb/s)
thanks
HD channels usually take up to 5Mbps.  So 20x5=100Mbps on the uplink. This is if all 20 clients are using IPTV at the same time and all are HD.  So, 1Gig uplink should be sufficient.
thanks for you response
actually when i contact with IPTV provider they told me HD channel require 16 Mbps
and when i search on the internet i found it's between 8 and 10 Mbps
and you told me usually take up to 5 Mbps
so i'm so confused about this matter :/
and if the Uplink sufficient or no
can you please understand me and help me with more information
thanks
okay Reza thank you so much
have nice day :)
The other thing I forgot to mention earlier is that with IPTV, you usually run Multicast.  So, it is one stream to many and not one to one like unicast.
So you should be fine.
Glad to help.
Thanks for the rating!
hi Reza
i know that is exactly about the multicast streaming
thank you so much for your advice and help
have nice day
