IPX over 2960 Lan Lite
jmecklenburg
Level 2
Level 2
Hi NetPro
A Swtich Cisco Catalyst 2960 whit Lan Lite software support frame whit IPX protocol?
Regards.
fixie rider
Edison Ortiz
Such switch is completely Layer2 so it doesn't support IP nor IPX routing.
If your IPX segment is local and no routing is needed, the switch will simply forward the packet in the local segment and no configuration is needed on the switch.
HTH,
__
Edison.
Ok Understand
Thanks Edison.
fixie rider
