IR829 Console opening issue
susmukhe
I am facing some issues when I try to open IR829 console using minicon.
And how can I switch to "rommon-1" from "rommon-2" ?
Please help me to overcome the issue as I am totally new with IR829.
rommon-2> boot flash:/ir800-universalk9-mz.SPA.156-3.M
Booting image: flash:/ir800-universalk9-mz.SPA.156-3.M.... [Multiboot-elf, <0
x110000:0x9d764bc:0x4a85f8>, shtab=0xa32f2f8[csvds]:/ir800-universalk9-mz.SPA.1
56-3.M... , entry=0x1100b0]
[CU:0]
Jumps to: 0x1100b0
Smart Init is enabled
smart init is sizing iomem
TYPE MEMORY_REQ
Onboard devices &
buffer pools 0x03644000
TOTAL: 0x03644000
Rounded IOMEM up to: 55MB.
Using 12 percent iomem. [55MB/448MB]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, ir800 Software (ir800-UNIVERSALK9-M), Version 15.6(3)M, RELE
ASE SOFTWARE (fc1)
Copyr<3> [95.113104] IOAPIC: IOAPIC 1 initialized, implementation version 32
<3> [95.113104] <E1000> e1000_device_init: initialized E1000 device
<6> PCI: Initializing
<6> PCI: Resetting devices
<6> PCI: Resetting device QAT15 (00:0b.0)
<6> PCI: Resetting device SMBUS1 (00:13.0)
<6> PCI: Resetting device ETH0 (00:14.0)
<6> PCI: Resetting device ETH1 (00:14.1)
<6> PCI: Resetting device ETH2 (00:14.2)
<6> PCI: Resetting device ETH3 (00:14.3)
<6> PCI: Finished resetting devices
<6> PCI: Restoring devices
<6> PCI: Finished Initializing
IOS image signature verification was: FAILURE
Autoboot string flash:ir800-universalk9-mz.SPA.156-3.M,12;
Failed to boot, skip first flash:ir800-universalk9-mz.SPA.156-3.M,12;
0 Replies 0
