Is 100mbps supported on Nexus 9500?
mazingaksk
Creating quote on Nexus 9508 with N9K-X9788TC-FX and N9K-X97160YC-EX line cards.  Is 100mbps supported on one of these line card ports?
5 Replies 5
No, 100Mbps is not supported. The minimum is 1Gbps.
HTH,
Meheretab
HTH,
Meheretab
balaji.bandi
These are next generation DC environment switches, cisco keeping in view design for the modern compute technilogy there there is no 100MB requirement (i understand the difficulties what about legacy infrastructure, that is the limitaion here).
we had same scenario something simlar, we need to retain one of the old switch which can support some legacy stuff like 100Mb.
N9K datasheet for refrence :
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/datasheet-c78-736677.html
BB
Remi Astruc
Previous statments are not right.
N9K-X97160YC-EX supports 100M on GLC-TE since 7.0(3)I7(4).
I use that already without issue.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/release/notes/70374_nxos_rn.html#_Toc532579213
Remi
Hi Remi,
You are absolutely right. Thank you for providing the correct info.
Meheretab
HTH,
Meheretab
Good to know, GLC-TE support
Speed—100Mbps on GLC-TE support for Cisco Nexus N9K-X97160YC-EX Line cards.
BB
