10-07-2008 08:47 AM - edited 03-06-2019 01:48 AM
I realize that the VSS Channel/VSS Feature is not supported in the 6513, but is the VS-S720-10G-3CXL
Sup card supported. In addition, are FWSMs and IDS cards supported?
Bob
Solved! Go to Solution.
10-07-2008 08:54 AM
Bob
Yes the supervisors will work in 6513 chassis - see this link about 1/2 way down
Yes also for the FWSM and IDS-M modules.
Jon
10-07-2008 08:54 AM
Bob
Jon
