Is it allowed to mix auto links and fixed links on Nexus vPC ?
omatsu
Please tell me about the VPC specifications for Nexus switches.
We use two dedicated lines to connect two locations and make line redundancy by creating a vPC on two Nexus switches that accommodates the lines.
*This dedicated line allows the link status of one site to be communicated to the other site using link pass-through function.
This time, our line operator contacted us regarding changes to their equipment and asked us to change the accommodation port from auto-link to fixed-link.
It seems that we need to put the following command into each of the vPC pairs, Nexus01 and Nexus02.
SW# conf t
SW(config)# interface Po 20
SW(config-if)# speed 1000
SW(config-if)# duplex full
SW(config-if)# end
During the configuration process, auto-links and fixed-links will be mixed on the member ports of the vPC, but I am not sure if this is allowed, so I tried the above operation using a free port and found that it was not possible to configure it.
It turns out that it can be done.
However, since I tried it with a link-down port without a transceiver (Now, I don't have a spare transceiver on hand...), I'm not sure if it can actually be done with a link-up port or if it will affect communication.
I checked the documentation, but it's not clearly stated, so I'm worried.
If anyone knows how to use this, please let me know.
Reza Sharifi
Most providers want their customers to hard-set the interface and not use auto negotiations. If this is the case, you need to apply the above command to physical interfaces and not the Po.
